Question about Saeco Odea Go
Lost part. the steam wand nozzle is missing - Saeco Odea Go
  • Saeco Master
  • 1,711 Answers
Steam wand doesn't work on sunbeam cafe series coffee machine
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Sep 11, 2012 | Sunbeam Cafe EM6910
Lost nozzle on steam wand of Francis Francis x7
I did a quick search, and unfortunately, your only realistic options are to either fabricate yourself one, or try to get one via the manufacturer.
Sep 02, 2012 | Illy Francis Francis X7.1 iperEspresso...
I have an Ascaso Steel Duo Professional semi-automatic espresso machine - the steam wand is restricted. how do I remove it to clean?
Hi There, If your ascaso steel duo is not producing steam,
Could be that:
The thermoblock may be blocked - Try descaling.
JURA descaling tablets
Steam wand may be blocked - try removing steam nozzle/steam wand and submerge in hot soapy water.
May 01, 2011 | Ascaso DUO PROF Stainless Steel Espresso...
Francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Feb 07, 2010 | FrancisFrancis! Coffee Makers & Espresso...
Wega mininova - steam wand not functioning
try cleaning steam tip with small paper clip. if coffee is hot then steam wand is blocked. Try using a de-scale solution.
Sep 20, 2009 | Coffee Makers & Espresso Machines
Need replacement steam wand sleeve
http://saecooutlet.com/ has parts and help for the sirena machine
Jan 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Jan 14, 2009 | Gaggia Classic Espresso Machine
Nozzle won't stay on steam tube
There should be two rubber pieces inside the threaded collar & cap that help produce a pressure fit onto the wand itself. There is a total of five plastic pieces on my steam wand excluding the wand itself on my Via Venezia by Saeco I purchased a year ago. Sounds to me like you lost one of you rubber gromets! Just my thoughts!
Dec 20, 2008 | Saeco VIA Venezia
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Steam wand not working
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
Saeco Odea Go Logo
178 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
