Question about Sony Playstation 3 (PS3) Console
Replacing blu-ray I would like to take the case of ps3 apart, so I can replace the blu-ray, can any body help?
  • mrios Apr 27, 2008
    I would like to know how to remove case in order to replace the blu-ray.
  • 4 Answers
There seems to be a good guide to performing this process here, http://edpsystemssupport.com/index.php?option=com_content&task=view&id=29&Itemid=45I will be buying one and giving this a whirl as well. Good luck to us!
-Steve
Posted on Apr 29, 2008
Tip
PS3 Won't accept discs - Here is the fix!
This tip is for people who have already disassembled their Play Station 3 console and tried to replace the laser in the Blu ray optical drive.
If you replace the laser and then reassemble the Blu ray optical drive and the drive will no longer accept discs (like there is something blocking the disc) follow these steps to resolve.
(NOTE: if your PS3 is not accepting discs because the disc just won't push in, not like there is something solid blocking the drive, or your drive is making "grinding noises" refer to this tip: http://www.fixya.com/support/r4321102-bluray_drive_ps3_makes_grinding_noise )
Remove the metal casing of the Blu ray optical if you have not already done so. This requires removing the three black screws and the two silver screws on the bottom of the Blu ray optical drive.
With the metal casing removed, locate the 5 black screws on the top of the Blu ray optical drive to remove. There are two on either side and one at the back in the middle.
Keep the drive together for now (do not take the top off) and reattach to your Play Sation 3 console.
Turn on your PS3 and wait for it to power up.
Now, take the top of the Blu ray optical drive by “unfolding it” so the top of the drive rests on the PS3 power supply.
With the top off, hit the Eject button on the front of your PS3.
The drive gears should “pop” back into place.
Turn off your PS3 and reassemble the Blu ray drive. You should test your Blu ray drive first before reassembling the whole PS3.
on May 13, 2010 | Video Game Consoles & Games
Tip
Bluray drive on PS3 does not accept discs after disassembling
on Feb 16, 2010 | Video Game Consoles & Games
Purchased 60GB backward compatable PS3 ( used). Will not play games, PS2 or PS3, they freeze up.
There are 3 main causes and solutions:
Software Issue (Restore the PS3 to factory settings via Sytem, Settings, Restore PS3
Dirty blu-ray lens ( take the PS3 apart and clean the laser eye carefully with a DRY q-tip.
Faulty / Failing blu-ray drive ( check and secure all of the cables to the blu-ray drive)
If the issue persists then more than likely you'll need to swap the blu-ray laser out with a new one.
There are a ton of guides on ps3hax.net and youtube.
Hope this info helps!
Oct 14, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will no longer play any of my games but will play dvds. I've kept the ps3 clean and as dust free as i could since i've owned it. I have recently put a blue ray cleaning disc but only after ps3...
I am afraid that your blu ray laser has become faulty. It is however not the end of the world as you can buy replacement lasers for around £60. Failing that you could buy a faulty PS3 off of ebay for around the same money and use the complete drive out of it. You must make sure however that you keep the circuit board off of your blu ray drive as it is paired with the motherboard of your PS3. You need to swap it to the replacement drive if you decide to do it that way. Replacing the whole drive is certainly easier than replacing the laser as you don't have to take so much apart.
Hope this helps and thank you for using FixYa
Sep 26, 2010 | Sony Playstation 3 (PS3) Console
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 plays movies but wont recognize games
    The PS3 uses a different laser for DVD's, Blu-Ray disks, and CD's. It's quite likely that just the Blu-ray diode has crapped out. have you upgraded to firmware 3.10
    For the player to work perfectly the lens needs to be clean. One piece of dirt can cripple your PS3 and end up with your PS3 not playing games. This dirt needs to be cleaned off the lens occasionally to avoid you having ps3 problems loading games.
    Try these steps to resolve this issue:
    You could be facing a lens related issue or corrupted firmware problem
    try this
    1. Update your firmware (if you aren't running the latest already). Yup, this overwrites some of system software that may have been corrupted.
    2. First, back up your game saves, and any music you have on your HDD. Format your PS3, this fixes corrupted files on the HDD by forcing the PS3 to rewrite them.
    3. Try cleaning the blu-ray drive lens with a Blu Ray Lens Cleaner
    if this does not help, i suggest should be send to Sony for repairs in case your PS3 is under warranty your replacement drive may be covered still you need to check with PS3 customer support, Laser replacement would cost you around $130.
    Hope this helps, and please do rate my solution, Happy Holidays and Happy gaming ahead!
    Regards
    KreativeGeek
    Dec 29, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 has just started to stop playing blu ray films after 20min
    the laser is starting to go bad in the dvd drive. It takes more power for the drives laser to read and play a blu ray movie then it does to play a dvd game.
    You can either replace the laser if you have the technical knowledge to take the dvd drive apart, or just replace the drive. You can usually find either one on ebay.
    Aug 04, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 wont read blue ray discs
    I had the same issue with my 60GB model, but I did not open up the case. Sony will fix your PS3 (no matter the warranty) for $150.
    To me, I would rather spend $150 by getting the blu-ray drive replaced than a whole new system.
    It's actually a very fast turnaround time. They send you a box which most people call the "coffin", you put your ps3 inside and take it to the post office. Pretty quick and painless from my experience.
    Apr 03, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 not playing blu-ray
    Happened to me this week - took it too a games repair shop and they did a ''quick reformat'' (not full reformat option, may take over two hours)....anyway - it worked and it's now playing Blu-Ray again...whaa hey - You can do this at home, I just didn't wanna try it just in case it refomated everything like on a PC - hope it works for ya
    Mar 18, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    14 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
