Question about Nokia 1100
Dd - Nokia 1100
    Genius:
  • 1,196 Answers
What is the problem? I will appreciate if you can give details of the problem.
Take care.
Posted on Aug 05, 2010
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
I have a samsung washing machine, a error message came up on the screen. 3e. we were advised to contact our after sales. we did, we were told by a service eng; the mother board was dud can you please...
Switch off the power/reconnect and try again, try unplugging power cord for two minutes, if problem persist follow instructions at the end of user manual to call service
Jul 24, 2008 | Samsung Washing Machines
I cannot put my bday in and it turns blue
Have you tried all formats of date?
dd/mm/yyyy
mm/dd/yyyy
yyyy/dd/mm
and so on......
Sep 02, 2015 | HP Computers & Internet
Trying to login new account won't except date of birth?
u might need to try different fomat for the date of birth such as:
DD/MM/YYYY
MM/DD/YYYY
DD-MM-YYYY
MM-DD-YYYY
MMDDYYYY
DDMMYYYY
Jan 10, 2014 | Computers & Internet
Ps3 hardrive corrupt and fails to recover
Try THIS
What you will need:
  1. Bad PS3 hard drive
  2. New hard drive of equal or larger size
  3. SATA to USB cable or a spare USB enclosure
  4. Copy of 'dd' for the OS of your choice
    • (Linux and OS X users should have it by default, Windows users can get it here)
  5. Time, patience, and a desire to recover your data
The process:
  1. Remove bad drive from the PS3
  2. Connect bad drive to a computer that has enough free space as the size of your drive
  3. Make a backup image using 'dd'
    • WARNING! You should be able to do this without having administrator/root/superuser rights. However, if for some reason you have to do this with admin/root/su rights, PLEASE, quadruple check what you type and make sure you have the correct paths. It is entirely possible to completely ruin a system install if you overwrite your computer's main hard drive and 'dd' will do this without blinking an eye if you tell it to.
    • The command I used was
      • dd bs=10M if=*path_to_your_ps3_hdd* of=*path_to_ps3_save*ps3_save.dd
    • Where *path_to_your_ps3_hdd* is the full path to the bad drive and *path_to_ps3_save* is the full path to where you want the backup image to be stored.
    • For example, I would've used
      • dd bs=10M if=/dev/sdb of=~/OMGPLZWORK/ps3_save.dd
    • As a Linux user "/dev/sdb" was the path to the bad drive when connected via the USB adapter and "~/OMGPLZWORK/" was the path to where I wanted to save the image.
    • Note that you DO NOT want to specify a partition number (/dev/sdb1) as you want to image the whole drive. There probably won't be a partition number, but just in case.
    • If you are a Windows user the command would look something like this
      • dd bs=10M if=\\.\e: of=c:\OMGPLZWORK\ps3_save.dd
    • Note that dd for windows requires "\\.\" before the drive letter.
    • Please read the "dd for windows" website if you are at all confused.
    • And for OS X users it would be something like this
      • dd bs=10M if=/dev/disk2 of=~/OMGPLZWORK/ps3_save.dd
    • As with Linux, you DO NOT want to specify a partition number (/dev/disk2s1) if there is one.
    • Note: '~' is a shortcut to your home directory.
    • Linux and OS X users (and I suppose Windows users too, if you wanted to install gzip, but I won't cover that) can use a variant of that command that will compress the image as it's created
      • dd bs=10M if=*path_to_your_ps3_hdd* ' gzip -9 > *path_to_ps3_save*ps3_save.gz
    • This will not compress the image much, as it will only compress free space on the drive, but it took my 320 gigabyte drive to around 260 gigabytes.
  4. Connect new drive to the same computer
  5. Restore image using 'dd'
    • The command to use is
      • dd bs=10M of=*path_to_your_ps3_hdd* if=*path_to_ps3_save*ps3_save.dd
    • or if you chose to compress the image
      • gunzip -c *path_to_ps3_save*ps3_save.gz ' dd bs=10M of=*path_to_your_ps3_hdd*
  6. Install new drive into the PS3
  7. Boot up the PS3 and let it attempt to restore
Note: If you have the available hardware, there's no reason you couldn't just 'dd' the data from the bad drive directly to the new drive.If you wanted to do that the command would be
  • dd bs=10M if=*path_to_your_bad_ps3_hdd* of=*path_to_your_good_ps3_hdd*
For example
  • dd bs=10M if=/dev/sdb of=/dev/sdc
If you choose to do this, you run the risk of writing the new drive over your bad drive if you have a typo (even if you're not running with admin/root/su rights!), so quadruple check the command and paths before executing.
If all goes well your PS3 should be back up and running with little data loss. However there is NO guarantee that this will work for you. If you're like me, though, it's worth a shot and you never know, it just might work.
Nov 21, 2013 | Sony PlayStation PS3 Slim 120GB Bundle...
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
How do I hook up a G wireless router to my h/p computer
The usual setup is to connect your internet cable or dsl model to the WAN port on your wireless router. any devices that were formerly connected to your cable/dsl modem then get connected to the LAN ports on your router. You will need to connect to the wireless router via etehrnet cable the first time in order to setup your wireless connection, it's usually a simple setup following the prompts.
Sep 29, 2009 | Belkin (F5D8231-4) Wireless Router...
There is a hum sound in the audio.
check your grounding.especially your cords.
May 17, 2009 | Lite On DD-A500GX Player
Vixen Telescope DD-1 Dual Motor Controller for RA and Declination
Vixen can repair your telescope-- and or the controller--
Contact OPT at this web site -- they are a Vixen dealer and can advise you about what to do--
http://www.optcorp.com/
Apr 10, 2009 | Vixen U.S.A. Great Polaris Telescope Mount...
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Nokia 1100 Logo
22 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
