Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer was working Ok and then the lights started flashing and dryer shut off and started beeping.. The cool down light is on and the drying light is on also..The drum door is closed.
I had the same problem and called the technician out, the door was slightly loose and not touching the small sensor (that is on the front of the dryer) properly. All he did was tighten up the screws for a cost of $100!
Posted on Aug 07, 2010
Kenmore electric dryer model 88042 runs but stops short beeping
Based on symptom and details, the control has detected a component failure. Since your model does not have digital display window in order to display a fault code, it will flash the four indicator lights of
Drying, Cool Down, Wrinkle Rid (Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator light will flash the number of times for the second digit.
Take separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light will flash four times indicating the 4. The four indicator lights and the START indicator light
start flashing at the same time. The control will pause for 2 seconds, then repeat the code.
The failure is likely because of a faulty thermistor or because the heater is not working. It could have a broken heating element or a burnt wire connection at the control board. I would begin by accessing the thermistor and disconnecting it. The thermistor can be tested with an Ohm meter. The thermistor should measure approximately 50,000/5K Ohms at room temperature.
The heating element is located behind the drum and it can be disconnected and tested for continuity with an Ohm meter.
NOTE: Disconnect the dryer from the power supply before servicing.
Jun 02, 2018 | Kenmore Dryers
GE Dryer possible control board problem
Get another one with a good name and sell your old one on eBay and get a good price for it.
Jan 12, 2015 | GE Dryers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer, model leq1452kso, does not start
some of these dryers have a fuse on them , I think that what it is or bad switch so ck for power to it ,
Mar 28, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Beeping Sound on Dryer
okay, this same problem happen to kenmore elites, the touch panel will automatically come on and beep even when it suppose to be off, replaced not the board but the touch panel and you will be okay.
Aug 17, 2009 | Frigidaire FEQ1442ES Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
459 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
