I have a Rosewill RC216 RAID card with two 250GB hDD set up under RAID 1. Can I break the RAID using the RC216 BIOS without losing data in either or both drives?
  • 4,806 Answers
Yes you can break the RAID 1 setup without loosing data as RAID 1 is know as mirroring. This means it keeps a mirror image of the drive that you are using just in case a drive goes down.
If you were using a different RAID setup like striping for example then you would loose data as that configuration stores different information on both drives.
You should be able to break the RAID 1` operation without loosing any data.
Regards.
Posted on Aug 05, 2010
What is RAID? Can this cause video issues? Can the Video problems be ralated to the PSU?
RAID is where you use data in stripes over many disks to improve reliability, one disk can go down and can be replaced without rebuilding machine. RAID is not appropriate for a single disk machine.
Jun 23, 2014 | Dell Dimension 8100 PC Desktop
Windows server 2008 raid setup on a dell poweredge 2850
2 drives indicates they are RAID 1, which are mirrored. 2 x 36GB = 36GB. This is an industry standard config. If you make any changes you will lose the array making it RAID 0 (no RAID - no longer hot swap), and or the complete loss of OS / data.
Instead make another logical drive for data storage. You need three or four drives to set up as RAID 5, again an industry standard config.
Make sure to back up in all instances. GL
Nov 14, 2012 | Dell PowerEdge 2850 3.8GHz 2u Server...
I was assembled a PC to edited video HD. This PC comprises: mothercard Supermicro X8DAH+, 24 GB of RAM, 2 X Xeon 5620, 1 X SSD OCZ Agility 2 3 X HDD Hitachi 1TB CD/DVD/BR LITEON ihbs112 GPU...
Remove the 3 hard drives and install Windows on the SSD. After successfully installing Windows you can add the hard drives and create your raid array later. Or even better, pick up a cheap RAID card so your CPU doesn't have to do all of the RAID controller work.
Dec 15, 2010 | SuperMicro X8DAH+F motherboard Intel 5520...
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
I have recently purchased a new HDD (I now have 2 Hitachi P7K500 HDDs) and built it into my system. I have first formatted the HDD I already had, then configured my BIOS for use of RAID 0. My mobo (MSI...
1. If you are just setting up your computer to have an a regular HDD and Backup HDD, i would think you should be able to set that up by booting onto your computer regularly, go to start, then into My Computer and right clicking on the HDD you want to set as Raid 1.
But if just want that other HDD for Space on your computer, all you had to do was plug it in and there you go... extra space.
Now if your installing windows 7 on the other drive i would find that pointless because you already have it on your first drive unless your putting 2 operating systems onto your computer.
Hope this helps.
Feb 27, 2010 | Microsoft Windows 7 Ultimate for PC
RAID-1 failure on Dell Dimension 9100 Desktop
Since you are using RAID 1 (Mirroring) you will only need to send one drive for data recovery.
Since the Dimension 9100 uses SATA HDDs yes you can increase the storage capacity up to a matched pair of 650GB drives. I'd suggest you use the most current BIOS revision, but SATA controllers seem to be much more agreeable to large HDDs vs the EIDE ones before them.
RAID is redundancy, but it is not a data backup, as you have learned. Important data should be backed up to DVDs monthly/quarterly etc. and you can even do critical backups weekly.
Jan 06, 2010 | Dell Dimension 9100 PC Desktop
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Disabling Raid Utility
Hi under Advanced in your bios is there anything like Raid Rom if so try disableing it then your pc wont look for raid devices and u should be able to boot strieght to your HDD u have installed
Jun 24, 2008 | Intel Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
How to move adaptec SATA 1420SA card from one PC to another
Man_K, Switching the raid card assemnly shouldnt make you lose any data on the drives.
After you install the setup on your motherboard. Windows should start and attempt to install the motherboard drivers. Before windows starts got to the BIOS and set it to defaults.
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
