Question about Cell Phones
I input my charger into my phone and it says charging but the battery goes down. And wen I take the charger out, it says discharging.
  • 415 Answers
It sounds like the memory of the battery may be faulty,
there are 2 possibilities
1. let the battery go flat completely/discharged and wait for a couple of hours and charge up again, this may help to reset the memory or
2. Change the battery, see if you can take your charger and phone to a store put the new battery in and charge and see if its really a problem with the battery if so then buy a new one,
good luck
Posted on Aug 05, 2010
Phone won't hold charge. Goes from 100% to 1% over night.
Replace new battery. You should be good to go back to business
like before.
Good luck
mai
Aug 16, 2017 | Cell Phones
My battrey is not charging
1) is the power source active (some wall sockets have a switch to render power there inactive -Australia)
2) is the charger plugged into an active power strip or an active wall socket?
3) is the charger damaged?
4) how long has the cell phone been charging? If the battery was completely discharged, it may take a bit for it to show a screen of it charging.
5) if the battery will not accept a charge, it will have to be replaced. Lithium batteries retain longer life spans if you charge them when power level is down to about 20 percent, NOT when they are completely discharged.
6) Better write down the battery number and amps when you pull the battery and keep it with phone documentation.
Jun 12, 2017 | Cell Phones
My phone keeps saying it's charging when its not even plugged in. But although it says its charging the percent of the battery goes down real quick what can it be. And if I connect the phone to the...
check the input and spray compressed air to clean.. do not blow into it cause moisture is expelled when blowing. turn of device and remove battery. spray again. wait 15 minutes. place battery back in power on
Oct 04, 2017 | Cell Phones
My nokia 5130c-2 starts charging automatically when i put in the battery without connecting the charger, then the battery discharges in a few hours..... pls help me.
There might be some battery issue you need to replace this battery to another one and please don't left your mobile while you are charging battery cells going to dead if its over charge and you will going to lose your battery and mobile as well Laptop Rental Laptop Hire in UK Wales Ireland and Scotland Hire Laptops
Oct 23, 2017 | Nokia 5130 Cellular Phone
My phone will not charge. I can connect it to the charger and it looks like it is charging. Remove the charger then phone goes off. I charged the battery with a stand alone charger then installed battery....
It maybe a problem on the phone already and not on the battery. Something inside the power ic / board that's why any battery will not hold charge for long. Try also draining the battery and then charging it for a full 2 hours with the phone powered off as this charges the phone faster.
Mar 07, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
I have some liebert ups 6kva i have problem in charger circuit i find transistor 13n80 have a short circuit i replace it and replace fuse in charger board 6.3a but there still problem in charging batteries...
Hi, Thanks for contacting fixya. There could be many reasons.
1. The battery is old and completed its charge-discharge cycle.
2. The step down transformer (220/110V to 12/24V) coils got shorted inside.
3. For a trickle charger, the SCR might have gone bad.
Solution for 1. Take out the battery and charge it by another charger. You can use laptop charger, cell phone charger or any charger. You might have to do a little bit circuitry. Then after 2-3 hrs of charging see if the battery voltage goes to its peak. Use a voltmeter or multimeter to measure that. If the voltage does not goes to its peak then battery is faulty. And the charger circuit has no problem.
Solution for 2. Some times step down transformer goes wrong. Measure the output voltage by a multimeter and see if it is giving the voltage what it should be. If not then change the transformer.
Solution for 3. I don't know how to determine if an SCR is wrong. The easiest way to check is to replace it and see if the battery is changing.
Feb 02, 2011 | Liebert GXT210000RT208 10000VA...
BB Curve 8900 cant turn on!!! Pls help
Try to Re-Charge your phone with electrical charger for 6 hr,
then try it
Jul 14, 2010 | RIM Computers & Internet
How should I charge my 2go pc? Wait until it gets low then charge? I heard that keeping the charger in too long or when its too soon to charge can destroy the computer.
Every battery follows a charge discharge cycle. Say your batteryhas 1000 cycles, and it goes down every time you charge and discharge. Also if you're constantly on power for long, remove your battery.
Apr 08, 2010 | Computers & Internet
Question
yes you can leave it in the charger, how ever its better to let the battery discharge then recharge, on a side note does your phone seem to light up for no apparent reason? at random times? just wondering because mine does :)
Jun 25, 2008 | GE 28111 Cordless Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
