Question about Weller 8200 Soldering Gun
Tip screws for model 8200 are worn out, What is the screw size?
    Brigadier General:
  • 4,088 Answers
The tip screws are a drilled bolt for this unit. There isn't room to tap the barrel holes out further if the threads are bad. You used to be able to buy tips that were pre-loaded with the proper clamp bolts. Good luck!
Posted on Aug 11, 2010
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Sep 14, 2010 | Weller Welding Tools
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
The light comes on. It does not heat up. The gun worked a day ago, what's up?
The tip is probably dirty. Loosen up the screws on the side and pull the tip out. Clean them off by scraping them with a knife or with sandpaper. Put it back in and tighten the screws. It should work then. Sometimes it's just that the screws are loose.
Nov 29, 2009 | Weller 8200 Soldering Gun
Replacing tip
i have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
Nov 07, 2008 | Weller 8200 Soldering Gun
Remove keyboad help
Heres where you get your manual.
http://eu.computers.toshiba-europe.com/innovation/download_manuals.jsp
G'luck
Oct 24, 2008 | Toshiba Tecra 8200 Notebook
Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email adrianferra@hotmail.com
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Weller 8200 Soldering Gun Logo
123 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
