Question about RTO Basement Watchdog Sump Pump
The alarm continues to sound. The red light for battery is on. I did add water and it went off for a very short time m, but then continued. I added more water, definitely full, and it continues to sound. Any ideas?
(Batteries may be substituted by using a deep cycle marine battery with the same specifications as described above, but the battery fluid sensor option will not function. Simply connect the battery fluid sensor to the positive terminal of the battery to disarm battery fluid sensor alarm).
Posted on Dec 06, 2011
  • 5 more comments
  • rlub Dec 06, 2011
  • kirtsmoser
    kirtsmoser Apr 19, 2012
    Yeah, I know. I read the install instructions. My battery sensor is connected to the positive terminal, yet the "Battery alarm" keeps going off (several times per week).
    When I reset the alarm, the pump runs dry for a while - which can't be good for it. I wonder if this is a design feature (called designed obsolescence) so that you have to replace the unit more frequently.
  • kirtsmoser
  • Bob Timm
    Bob Timm Nov 30, 2012
    Follow what colm_malo765 wrote below. I had the same issue and put a battery charger on it and let it charge while the unit was plugged in. The alarm went off on its own. The downside is, I know I need more battery acid, but I thought of that after I had added (topped off) the battery with distilled water. If your battery backup is running more then the sump pump itself, move the sensor/float up above the water line your pump (about 6 inches to a foot - not the battery) goes off. This will save you more headaches later (like battery draining and then sump pump fails during power outage).
  • bgill0
    bgill0 Dec 28, 2012
    I am having the same problem... I assume there is a problem with the charging system? This isn't a cheap system, I would expect issues like this after less than a year..
  • Dale John
    Dale John May 04, 2014
    My low water alarm kept going off. I checked the manual and found I had the probe inserted in the second cap on the negative side of the battery cell. I switched it to the positive side second cell cap from the end and the red light went out and No More Alarm.
  • Dennis Ward
    Dennis Ward Jun 21, 2014
    I've had a similar problem and found that the charger is boiling the battery.
I am having the same issue, did you get yours to stop?
Posted on Dec 02, 2010
  • 5 more comments
  • 2boxy Dec 02, 2010
    I have the same problem, did you ever figure out how to fix it?
  • fatboy1957 Jan 02, 2011
    im having exact same problem,had the watchdog sump and battery one year and now battery low water level keeps beeping,and water level is definitly full ,has anyone figured a solution to this?
  • 2boxy Jan 02, 2011
    I had to buy a new battery and new acid, about 141 dollars. The old battery lasted a little more than 2.5 years.
  • plumber610 Feb 03, 2011
    the watchdog systems always are alarming and require too much maintenance
    most of the the time they have to be sent in for repair after trying new battery, etc
    my advice is to cut your loses and buy a different brand system
  • colm_malo765 Feb 15, 2011
    i actually got the water alarm to stop !
    My battery is one with no hole for the fluid guage - so that goes under the positive terminal.
    In any case - i tried everything ... ensuring water fill, and sticking the fluid probe directly in liquid .
    That led me to think ... fluid level might be nothing to do with problem. So I recharged the battery overnight with my car battery emergency charger (in remote aerated corner of garage, in case of probs - but there were no probs ). In the morning, when i reconnected to the Basement Watch dog - I noticed sparks when attaching the positive terminal - so that was encouraging.
    After I connected it .... the water alarm was GONE !!. The battery alarm was sounding with an on/off frequency of about a second. But when i hit the alarm reset button, that went off - and everything looked good.
    It has been a couple of days now - and eveything is working fine.
    I think the problem is .... not that the fluid level is wrong, but rather that the battery is completely dead. Mind you .... before charging, as described above - I did replenish the acid (i.e. pour out some - maybe 2 or 3 cups, and replenish with some refill acid ($18) from Home Depot). This may have allowede the battery to take the charge, which solved the problem ........
    though charging without replenishing the acid may have worked too - i don't know. Either way, i'm happy, that horrible alarm is silenced - and my system is working.
    Hope this helps !! Good luck in your battery struggles ....
  • Dale John
    My battery low water alarm kept going off and had to reset it every 24 hr period. I checked the manual and found the low water probe is supposed to be inserted into a hole in the second cell cap from the positive side of the battery. Mine was on the negative side. I switched the cap and probe to the positive side. The red light went out and the alarm has stopped. Problem solved.
  • Anonymous Feb 14, 2017
    @colm_malo765 Thanks a lot for your comment. I wasn't able to figure out why things were not working till I read your comment.
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Green alarm light continuously on. Any ideas?
Green light usually means your water filter is in great condition . the light will stay on,over time change to amber then red. Red means change filter
Jul 22, 2015 | Refrigerators
Tv went crack while watching. Picture and sound went out & red light flashing.Waited a min,turned off and back ok with picture and sound returning concerned if we should continue using or not?
As long as you can see and here the picture with no problems you should be fine. The tv's put it heat which make things expand and contract. Sometimes things creek and crack. I've had two tv's that do that. Don't hesitate to keep a fire extinguisher handy though along with some alarms.(houses should have these at all times anyways)
Mar 07, 2015 | Televison & Video
Turn off alarm after jump starting car
You need the VW scanner to reset the system and reprogram it after loss of power to the system. Aren't VW's great?
Mar 15, 2014 | Volkswagen Passat Cars & Trucks
Protection light flashing and alarm sounding, unit was running and the unit just quit and the flashing light and alarm came on
Will the unit power up without the cb radio? I would suggest a short somewhere in the system if the protection light continues to shine bright.
Mar 24, 2013 | Pyramid (PS36KX) 600-Watt Power Supply
Anti theft alarm goes off at different times & different places with no reason-2002 Sable Merc.
Had a new Lincoln Mark 7, battery was bad from beginning and would trigger alarm when it shorted at random. In your case, outside radio waves may trigger alarm if shielding was removed from alarm antenna.
Aug 31, 2017 | 2002 Mercury Sable
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
RTO Basement Watchdog  Sump Pump Logo
16,610 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
