Question about Gateway FPD2185W 21 in. LCD Television
DCDi monitor - model 2100 has been been flickering in and out of black screen until it appeared to warm up but had to turn off and on to get monitor to work until it warmed up. This has now stopped.working and has about 3 seconds of normal screen time then blacks out.. is this a hardware /driver problem or something else? I'm using an older EVF720 monitor from gateway to type this and it has problems too. looks like color issues but I think it may to black out too
  • 36 Answers
It is a power board failure, needs to be service by a qualified technician. It is a small service project. For more info email Sprint@zoominternet.net.
Posted on Jan 25, 2011
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
When i plug it in and turn it on. it takes minutes to warm up. flickers on and off on a black screen.
the flickering is normally due to an EST about to go bad so contact a local tech who repairs monitors and get the EST checked
Dec 08, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
Acer monitor model # AL2223W screen goes black
need some clarifications on here. you connected the Acer Monitor to your Dell laptop right? when you opened the screen goes black. i believe you have to press the FN + F7 or FN + F5 on your laptop to make a display on the Acer Monitor.
Apr 14, 2010 | Computers & Internet
I have a Gateway HD Monitor Model 2100. The screen flickers and turns off. I can cycles the on.off button and it comes back on, only to flicker and turn off later.
Either you have a problem with the back light or inverter.
When you disconnect the unit from its signal connection, you should see no signal input message.
If the unit flickers and then go out, while disconnected, you can rule out the video card and assume it is the back lights or inverter.
90% of the time, it is the back lights.
Nov 24, 2009 | Gateway FPD2275W LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
966 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
