Question about Dell 2161DS (DELL2161DS) 16-port KVM Switch
Cant reset password on dell 2161ds kvm - Dell 2161DS (DELL2161DS) 16-port KVM Switch
Reset password log in KVM SwitchView1000
This is the reset process for the SV1000 password. Enter all 0s in the password field, without pressing the Enter key and use a small pin to press and hold the reset button for 3 seconds or so that is located in the back of the sv1000 switch next to the power adapter#s connector. This process does not require the user to turn off the power for sv1000 and its connected target PCs.
#TreasureIt... It doesn't come easy.
Nov 28, 2013 | Avocent SwitchView 1000 - KVM switch -...
How do I reset the password on my Avocent AutoView® 2015 KVM Switch
I believe there is a reset button somewhere on that unit that you can press to just do a quick reset of it. If you hold that button down, you should be able to reset the settings on it, including your password. Hope this helps.
I hope this helps you.
Oct 14, 2009 | Avocent AutoView® 2015 (AV2015-001) KVM...
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
Dell kvm switch
I've had that happen when I've added some newer rev SIPs. The newer ones come with a notice to load the 2161DS with versions 2.0.13 or newer firmware; by unplugging the new SIPs and leaving just the older ones (and I'm at a loss as to the exact revisions) I got back the OSCAR prompts. Plug the SIPs back in one at a time, and they would display, but once the session timed out, the key sequence would do nothing once again. Don't know if this is what you have, but I do know that certain SIPs can interact with your firmware to cause this symptom - my bigger problem now, is that when I try to update with the newer firmware (d2_0_13_english.fl) I get a message: "Unable to upgrade the firmware. Reason: Incompatible file."
Dec 11, 2008 | Dell 2161DS KVM over IP Switch (1P500) KVM...
USB mouse not recognized
I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
Feb 18, 2008 | Dell (582RR) 16-port KVM Switch
Compaq 4110 KVM - reset Password
small hole in back stick a paper clip in it and while pressing button power on and hold foe 30sec this should do it
Dec 02, 2007 | Compaq 242695-001 8-port KVM Switch
Computers & Internet Logo
730 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
