Whenever i start my pc fan's start's even monitor start's imediately but 'no signle' massage appears on screen & monitor screen got off
Do you get any "Beep" sound coming from the internal speaker, if so is it just one straight beep or numerous beeps.
If it's one straight beep then this indicates the PC has passed it's POST (Power On Self Test), if it's a series of beeps, some long, some short, it means there is some problem inside the computer, like loose graphics card, RAM, CPU, cable, etc. The beep sequence should be in your motherboard manual under beep codes. That will give you a hint as to what to look for next.
If it is one straight beep and PC passes POST then check your monitor connections, and monitor, it could be that the power saving/signal detection pin is either not connected properly, or damaged.
If you don't have the internal speaker connected (normally in the bottom or front of the case), you need to connect this to find out what is going on.
If you need to connect it you should look at your motherboard manual for where to connect it, normally if you look at the motherboard you will see a load of thin cables coming from the front of the case going onto the motherboard at a point, the 4 pins on the bank of pins at the end are normally the PC speaker (you also get a blank pin between them and the Power Switch pin), although check your manual first, or see if you can see the SPK connection on the motherboard (normally Gigabyte boards are very well marked for this, and colour coded.)
