Sound breaking up (distorted) when I play DVD'd
I have an Acer aspire 9423 laptop with philips DVD-RAM SDVD8821. When I play dvd's the sound is awful -it used to be OK. If I copy the DVD to the hard drive and play it from there its fine. I use power DVD but have also tried vasrious othr players eg VLC media player, winows media player -all with the same result.
  • mthornbu May 19, 2009
    Philips dvd-ram sdvd8821 sound is skipping when I play DVDs - used to be okay. What can I do to solve?
bmwrider
  • 215 Answers
SOURCE: JVC DVD player plays with distorted sound
Do you run your volume flat out? If you do then perhaps you've damaged the cones in your speakers. Some of these 5.1 speaker systems are utter rubbish. They look nice but the speakers are often garbage. Also running speakers at high volume for lengthy periods can overheat the coils and distort the cones.
Posted on May 26, 2006
sandrew
  • 2961 Answers
SOURCE: Using dvd drive makes makes sounds
There is nothing wrong with your laptop. If you are copying a cd and trying to play music at the same time, you are pushing the processor power of your laptop or low on memory. When copying a cd it should rip it without sound to your hardrive, so i assume that your are playing music from your hardrive as well as ripping and this model of laptop i think comes standard with a 1.3ghz processor with 512mb of memory, which can easily be drained when ripping or burning.
Posted on Mar 03, 2007
showsizzler
  • 66 Answers
SOURCE: DvD Player on PC
try and install decoder from updates of windows media player,and search for windows xp decoder ,and update ur windows
Posted on Mar 15, 2008
  • 3422 Answers
SOURCE: Stuttering Sound
Hi again,
I'll let you know soon if there is another solution to fix it within your two players..
Posted on Apr 30, 2008
charcois
  • 763 Answers
SOURCE: PC dosen't play sounds occasionally
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
CHARCOIS
Posted on Sep 14, 2008
Distorted sound on CD
Sound is distorted when the media is not being read properly, try cleaning the lens, tip : burn the cd's/dvd's at lower speed.
Jul 20, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Aspire 5515 dvd wont play sound
Does the laptop play CDs?
If so then when you start a DVD and before you play the movie, go into the audio setting and configure the speakers for laptop stereo speakers.
If you cannot hear music from the CD then check :-
1. The audio settings, volume not set to minimum and mute is not ticked (enabled)
2. Device manager - sound device is enabled and working, if not re-install the sound driver.
Nov 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Aspire 7738G-6006 looking for informationonthis
MSRP $799.99 General Specifications Manufacturer ACER Manufacturer Part # LX.PCC02.001 Cost Central Item # 10974418 Product Description Acer Aspire 7738G-6006 - Core 2 Duo T6600 / 2.2 GHz - RAM 4 GB - HDD 320 GB - DVD±RW (±R DL) / DVD-RAM - GF GT 130M - Gigabit Ethernet - WLAN : 802.11 a/b/g/n (draft) - fingerprint reader - Windows 7 Home Premium 64-bit - 17.3" Widescreen TFT 1600 x 900 CineCrystal - camera Approximate Dimensions (WxDxH) 16.1 in x 11.3 in x 1.7 in Approximate Weight 7.5 lbs Localization United States System Type Notebook Built-in Devices Stereo speakers, subwoofer , wireless LAN antenna Embedded Security Fingerprint reader Processor Intel Core 2 Duo T6600 / 2.2 GHz ( Dual-Core ) Cache Memory 2 MB - L2 cache RAM 4 GB (installed) / 4 GB (max) - DDR3 SDRAM - 1066 MHz ( 2 x 2 GB ) Card Reader 5 in 1 Hard Drive 320 GB - Serial ATA-150 - 5400 rpm Optical Storage DVD±RW (±R DL) / DVD-RAM - integrated Display 17.3" TFT 1600 x 900 - 24-bit (16.7 million colors) - CineCrystal Graphics Controller NVIDIA GeForce GT 130M - 1 GB Audio Output Sound card Telecom Fax / modem - 56 Kbps Networking Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft) Notebook Camera Integrated Input Device Keyboard, touchpad Power AC 120/230 V ( 50/60 Hz ) Battery Lithium ion Run Time (Up To) 3.5 hour(s) Operating System Microsoft Windows 7 Home Premium 64-bit Edition Environmental Standards EPA Energy Star Manufacturer Warranty 1 year warranty
Nov 12, 2009 | Acer Aspire One PC Notebook
PHILIPS CDRW/DVD SCB5265 ATA Device cannot play most DVDs
I'm guessing you may have locked the DVD region. If you right-click on the device in Device Manager and click the Region tab, does it say 0 changes available? Acer won't fix this, and claim you have to replace the drive. Can't find a firmware flash for this drive online, will post back here if successful!
Aug 14, 2009 | Acer Aspire 5535-5050 Notebook
My Acer 9423 has no picture or sound
Try remove ram memories, they should be under screwed cover at the bottom side. After a while put it back, do it very strictly. Make this all on removed battery, and power cable off. You may remove your hard drive too, then get it back. If this doesn't work, you can disassemble and check if the screen cables are well connected. They loose out sometimes.
Apr 10, 2009 | Acer Aspire 9420-6426 Notebook
Sound
THERE IS NO SOUND DRIVER THAT NOT INSTALLED IN YOUR ACER LAPTOP.
DID YOUR ACER WAS FORMATTED??
Jan 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
DVD cd player not working
HL-DT-ST DVDRAM GSA-T20LATA Device the dvd player not working
Jan 12, 2009 | Computers & Internet
Philips dvd ram sdvd8821 does not play
this the most costly part of the drive, better to get a new drive with warrenty
Oct 19, 2008 | Acer Aspire 5100 Notebook
Compaq DVD Player problem
You need a new DVD codec. If you have a copy of WinDVD, give it an install. Otherwise, try the free codec on www.divx.com.
Dec 06, 2007 | Acer Aspire 3000 Notebook
Code 39 on DVD Philips SDVD8821
Solution to this problem would be to either one track down the drivers on ACER website it should be there!
Or finde the part you are trying to get the drivers for online:
You do not have to go to Microsoft website for drivers
Google the device and drivers or go onto Philips website under support!
Oct 17, 2007 | Acer Aspire 5500 5570-2609 Laptop
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
Electro Med Services...
