Question about Grindmaster B-SAP Coffee Maker
Hi. My office has a Grindmaster/American Metal Ware "B-SAP" model coffee brewer and this morning it stopped working. The LED display is showing an error code "E2". I removed the top cover, checked the wire connections and they all appear to the naked eye to be OK. What is the common cause for an E2 code? There are several engineers in my company so if you could help steer me to what part needs replacing, I'm sure they could perform the installation. Thank you! Francis
  • fpuntney747 Aug 05, 2010
    When I look in a B-SAP manual that I found on the web, it states the an "E2" code refers to a problem with the thermistor or thermistor circuit ... the answer I received from the first expert on this site does not jive with that. So I'm asking for a second opinion please? What part usually needs to be cleaned or replaced when a B-SAP coffee brewer quits and displays the code "E2".
    (in response to the previous expert advice I received, it's hard to run the brewer through a brewing cycle with descaler solution IF it's not running).
  • 532 Answers
Here are some of the most common problems that can cause your coffee brewer to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the
The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably have to buy a new coffee maker if one of these problems disables your machine. Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Thanks for contacting Fixya
Posted on Aug 05, 2010
    Guru:
  • 632 Answers
Press the On/Off button to reset the Coffee Maker.
NOTE: If the Coffee Maker has been stored or used in a cool environment, warm the Coffee Maker to normal room temperature before doing this.
If reset is not clearing E2 then you would need to contact GrindMaster as they will do a free exchange for unit under the 2 year warranty. You can contact them at Phone: (USA) 1-800-695-4500
Customer Service & Technical Support representatives are available Monday through Friday from 8 AM to 8 PM EST.
Its a toll free number so doesn't cost a penny to contact them for advise or exchange under warranty, Make sure you try run the reset above make sure the machine is not in a cold room when doing it.
  • 1 more comment
    The unit has been used every day in our office which is not a cool environment; it just stopped working this morning out of the blue. Pressing the on/off button does nothing. I tried unplugging the unit to reset it but "E2" pops right back onto the display. What is the most common causes for an E2 code?
  • Simon Swales
    Simon Swales Aug 05, 2010
    Common reasons for e1 or e2 are generally clogs or deposits from the water build up over time .
    The coffee maker needs to be descaled.
    Run the coffee maker through a complete brewing cycle using
    a descaling solution. you can buy them from local stores
  • Simon Swales
    E2 Can refer to many problems, You asked common which is the build up of deposits in the pump, But can also be many other issues.
How do i adjust the blades/grinder on my Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 876
I don't see a model 876, but there is an 875s. Here is the wesite for frindmaster and the 800 number or user manual for help. Coffee Grinders
May 15, 2014 | CoffeeForLess.com Grindmaster Automatic...
How do you adjust the water level
After the first brew the machine should brew excactly the amount of water added to the water reservoir. Since the reservoir always keep half full then you should add the maximum amount you need in two steps.
Apr 07, 2012 | Grindmaster B-SAP Coffee Maker
Where can I buy a 220 Keurig brewer in the UK?
Upton Group announce partnership with Keurig UK Ltd
The Upton Group are pleased to announce their new partnership with Keurig UK Ltd, the UK division of the North American giant Green Mountain Coffee Roasters (GMCR). As members of The Wise Group we are part of the newly established official network of Keurig Authorised Distributors.
keurig-uk-supplier1.jpg It's so much more than just coffee
Grab a K-Cup pack, your favorite mug, press a button and Voila! There you have a fresh cup of coffee, tea or chocolate brewed in seconds. With a Keurig brewer in the office everyone can brew their perfect cup every time.
Once people try a Keurig brewer a funny thing happens. They love it. So we're giving your office a chance to try it - for free. If you would like to take us up on our offer then call our sales team on 01757 629 115 and ask for Keurig sales.
Apr 02, 2011 | Keurig Ultra In Home Single Cup Brewer...
How can the length of the garden hose effect the amount of work done ?
Digital Satellite Coffee Brew Centers Model: BC302E-IT Twin
The Operator's Manual for your product can be found here:
http://www.grindmaster.com/docs/Ni90A-BC-IT-MAN.pdf
WATER HOOK UP
The National Sanitation Foundation (NSF) requires the following for NSF approved installation:
1. A quick disconnect water connection or enough extra coiled tubing (at least 2x the depth of the unit) so that the Brewer can be moved for cleaning underneath.
2. An approved flow-back prevention device such as a double check valve to be installed between Brewer and water supply.
WATER CONNECTION
The Brewer comes equipped with a ¼ inch compression water inlet fitting located in the back. Use a ¼ inch copper tubing to connect the Brewer to a cold water supply. Water pressure should be: 20 PSI min. to 90 PSI max. An external shut-off valve and a water filtering system with a charcoal filter are highly recommended. Turn water supply on and check for leaks at the water inlet connections, tighten compression fitting if necessary.
Hook-up using a garden hose would not be recommended; if the hose is too long you may not meet the minimum required pressure and will have difficulty filling the machine.
Feb 16, 2011 | Cecilware Coffee Brew Center wWater Tap...
Good morning, My Keurig Special Edition doesn't get "ready" When I turn it on, "Not Ready" shows up in the window and after 15 minutes, it still shows "Not Ready". Can you...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 10, 2011 | Keurig B100 Coffee Maker
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Gm 875 parts
Any three-pole momentary switch with the correct rating would work. Try Radioshack or the like.
Good luck.
Dec 31, 2007 | Grindmaster 875 bulk coffee grinder
Grindmaster B-SAP Coffee Maker Logo
63 people viewed this question
Top Grindmaster Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
