Question about Maytag Ovens
I have a Maytag Wall Oven bought 4-28-2006 Model MEW6530DDS SN 13363140EP. The control panel has stopped functioning. Can I get an estimate of parts and labor? Sincerely, Jack Koyle Waterford, MI 38329
    President:
  • 1,430 Answers
Price of the part is $208 and average labor rate is $78. Most companies also charge a service call fee, this is the charge to come to your home diagnose the problem. This fee can vary from 0 to usually no more than $75. Be sure to ask when calling for service. For a DIY try this link http://appliancehelponline.com/ovenerc.html
Posted on Aug 05, 2010
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Its a Maytag wall oven and I need to replace the operating panel
usually you take off the handles with screws and the front panel is screwed to the door or held on by clips or brackets.
Jun 18, 2010 | Maytag Appliances 27" Electric Double Wall...
I have a Maytag in wall oven (part# MEW653ODDS). Only three buttons on the control panel are functioning (cancel, convection bake, and favorites). The oven seems to work properly, but the number of...
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Nov 03, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
MEW6530DDS keypad not working
Check out www.appliancepartssolutions.com for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
Aug 06, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Aug 02, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Ovens Logo
118 people viewed this question
Top Maytag Ovens Experts
Carmen Mikulic
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
