Question about Microsoft Xbox 360 Console
How do I set up my xbox 360 to play bbc iplayer, I have a dongle, wireless network set up, do I need to join xbox live? When trying to sign in, under my e-mail address then adding my password i'm told one of the above are incorrect, all i'm trying to do is acess bbc iplayer. Can you help me?
    Brigadier General:
  • 3,513 Answers
Hi
Please check this bellow link regarding your query…
http://www.pcpro.co.uk/blogs/2008/11/23/how-to-watch-the-bbc-iplayer-on-the-xbox-360/
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 05, 2010
How to get an internet connection for xbox live
Hello award ward,
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible
with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
michael34
Mar 09, 2011 | Microsoft Xbox 360 Elite Console
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
On my xbox 360 i can't connect to my friend and he can't connect to me and he told me i needed to change my router settings and i don't know how too and i have a DI 624
You trying to do a system link? If so then you just need to use the network cable you got with the xbox360 put one end in your computer and the other in your friends xbox. This will link your two xbox's without the need of going through the router. If you want to use the router to connect each other you will have to set up the network IP addresses that are set for your network manually. I can't tell you how to do this as I don't know anything about what network setting you using. If you want to connect to your friend over xbox live to play together sign up for select join xbox live from your avartar screen and sign up for xbox live you both will need an xbox live gold account. Once your gold accounts have been set up add each other as friends and then you or your friend can invite each other to games just remember that you both need a copy of the game you want to play in any case.
Nov 26, 2010 | Computers & Internet
My xbox360 doesn't let me play some game or download stuff
Your XBOX is not connected to the internet. If you are using an ethernet cable make sure that it is plugged in both to the Xbox and at the other end. If you are using a wireless adapter you need to check the settings and make sure that it is joined to your wireless network. Also, it is possible that you are simply not signed in to your xbox live account.
Are you trying to play a game online or from a disc?
Jan 29, 2010 | Microsoft Xbox 360 Console
How do i join xbox live i dont know howtoget internet on xbox live can you help?
You need to sign up through your xbox or by calling 1-800-4-My-Xbox. You need your xbox to be connected to the internet either by plugging in the network jack in the back of the console, or buying a wireless network adapter and hooking it up to your local wireless network.
Thanks
Tim
Dec 02, 2009 | Microsoft Xbox 360 Console
(2) xbox 360's in same home; 1 wireless adapter, other ethernet
you need to assign a static ip address to each inside your router they are more than likely using the same ip address
Jul 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter connects but can't join parties!
If you think its the wireless adapter, try using a laptop (that has wireless) to connect your xbox to your network. Just get a straight through (network) cable connect one end to the xbox and the other into the ethernet port on your laptop. Then go into your network settings and bridge the connections (if you don't know how to bridge connections try youtube or just google it) Now your laptop acts like your wireless network adapter. See if your problem occurs with the laptop, if not then it is the adapter. I hope this helped solve your problem.
Jun 22, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
