Question about Casio G-Shock G2600 watch
G-Shock - How can I turn off the sounds when switching between modes (functions)?
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
Feb 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
How do u turn off the alarm on a baby g shock. Like how do u turn it off forever?
mcdevito75 Here, You should be able to reach the alarm thru the MODE cycle, Press MODE and see Flashing display, press Mode for each function till you reach alarm and put alarm to off, if you have t1 and t2 time you"ll have to do this twice.
Oct 26, 2010 | Casio BG191 1B2 Baby G Watch
HOW DO U SET THE TIME??
mcdevito75 Here, You need the MODE and SET buttons. Press MODE and see the display flashing, now press set for each function, pressing MODE after eac function is set. Once all functions are set press MODE fpor steady display.
Sep 24, 2010 | Casio G-Shock G2600 watch
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I got my Casio G-Shock 4778 aw-590 battery replaced at a local shop(not a licensed g-shock dealer) and the jerks did not set the time and my manual for the watch was thrown out years ago!
mcdevito75 here, Return to the shop for this adjustment. Or you can try, press the mode button, see the display flashing, now press set for each function you want, after each function press mode again to move onto next function, hour minute etc., when all functions are set, presss mode again for steady display. You may have to press and hold down mode button from the start for 2-3 seconds to see display flashing, once you do, you can use set to adjust all functions.
Aug 17, 2010 | Watches
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
How do i set my casio G shock watch?
mcdevito75 here, Generally you need to press the MODE button, seee the display blinking now press set for each function, Hour, Minute after each function is set press mode to move onto next. when all set press mode again for steady display.
Jul 09, 2010 | Casio G-Shock GW500A-1V Wrist Watch
How to set the time
mcdevito75 here, One of the buttons should say MODE, press this button and see the display blinking, NOW, press set for each function you want to adjust, Hour, Minute etc, press MODE after each function is set, Hour, then Minute, when done with setting all functions, press MODE again for a steady display. Look for a small watch repair shop in your area for more help if needed.
Jul 03, 2010 | Casio G-Shock GW500A-1V Wrist Watch
How do you set this watch
mcdevito75 here, 1 button should say MODE press this button then press set each function you do press MODE again to move to the next function, day, date, hour, minute etc as each function s set press MODe to move to the next, when done press MODe to stop the flashing screen.
Jun 23, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock G2600 watch Logo
145 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
