My AC condensing unit does not turn on, but the air handling unit is on. What can be the problem?
    Genius:
  • 1,478 Answers
Do you hear the compressor running? If the compressor runs but the fan does not turn then that tells me the contactor is pulling in. Therefore, the fan should be turning. 99% of the time it is a burned out motor. Do not bother with the capacitor suggestions, it will be a waste of your time. Take out the motor, go to ACR or Johnson Supply, or Baker distributing, and get a matching replacement. Always get a new capacitor with the new motor. They are only 3 dollars and good insurance for the new motor. You will probably spend a total of 65 dollars. Get it done.
ps: if the compressor does not come on either then the problem is a bad contactor or thermostat or broken 24 volt control wire to the contactor. If the freon pressure is too low because of a loss of freon then a pressure switch could be keeping the contactor locked out. In the event of no compressor and no fan running, do not start off with the fan repair. Start off with the contactor and make sure it has 24 volts on the coil and that it pulls in.
Take care.
Posted on Aug 05, 2010
Why does my ac not blow cold air?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand
May 26, 2016 | Heating & Cooling
Why does the aircon cant stay on
Most modern air conditioners are designed to offer up to 10 to 20 years of reliable use. However, even the most reliable of air conditioners may stop cooling or suffer from problems from time to time. Remember that one of the best ways to prevent unexpected A/C problems is to have regular maintenance performed on your unit. If you cannot perform the maintenance yourself, hire a professional to do so. Spending money on maintenance now can save you from big repair bills in the future.
Some of the most common AC problems are listed below, and they may even be the reason why your air conditioning unit won't kick on. Review this information so that you know how to best troubleshoot problems with your unit. Be sure to determine whether your unit has shut down entirely or whether only a part of your unit has shut down or isn't working. Remember that it is always necessary to cut power off to your unit before inspecting it for wiring-related problems.
  • The AC unit does not cool rooms evenly: Inspect your unit's distribution channels. Make sure that the fan on your unit is kicking air into rooms or into your duct system.
  • The AC unit turns on but doesn't cool: If your unit turns on but doesn't cool, check your thermostat to be sure that it is set at the correct temperature. You should then check the condenser and evaporator for dirt and clogging. If too much dirt builds up, your unit may not turn on at all.
  • The condenser unit returns on and off repeatedly: Having a unit turn on and off repeatedly is extremely frustrating. In general, this problem is caused either by a dirty condenser and fan or a clogged condenser.
  • The condenser unit won't turn on: If your condenser unit won't turn on at all, you may have a faulty motor or the unit may not be receiving power. Examine all wiring and ensure that the unit is plugged in.
Sep 23, 2015 | Cars & Trucks
How do I determine whether or not condensate should be dripping from a window ac?
The amount of condensate depends upon the relative humidity of the air. When the humidity is high, the AC unit will create more condensate and when humidity is low less is created. As long as the AC unit is working properly, I would not get overly concerned about it.
May 09, 2015 | Frigidaire Heating & Cooling
Everytime my central air unit kicks on my circuit breaker trips. It didn't do this last year or even earlier this year
A circuit breaker 'tripping' everytime the AC unit kicks on 'most always' indicates a direct short (somewhere in the condensing unit), although it is possible that the breaker itself is bad - (but not likely).
Usually the cause of this 'short' will be - either the condenser motor in the condensing unit (outside unit) or the compressor - also in the condensing unit.
If you're mechanically inclined - and "very careful" around electricity - there is a fairly simple way to find out which component is causing the short.
Step 1 - Make sure the condensing unit (outside unit) is completely disconnected (electrically) , i.e. pull the fuses/turn off circuit breaker on outside unit and turn off thermostat.
Step 2 - disconnect the condenser motor (this is the outside fan motor). Note: when you disconnect the wires of the condenser motor "be sure" you mark/write their location, and wrap them in electric tape.
Step 3 - start the AC unit. If the breaker trips again you can pretty much rest assured it's the compressor that is shorted.
To prove it (without a doubt) - go to next step.
Step 4 - "be sure circuit breaker and thermostat is turned off" - and - 'reconnect' the condenser motor - and - then disconnect the compressor wires (mark wires and tape them).
Step 5 - Start AC.
If breaker doesn't trip - you know it's the compressor that is shorted.
If breaker 'does' trip again - then it's possible the breaker itself is bad (not likely) or there is a 'short' in the condensing unit's "wiring" somewhere (not likely).
My guess is that either the condenser motor or compressor is shorted.
Hope this helps.
Good Luck!
Jun 10, 2010 | Heating & Cooling
AC condenser will not turn off after unit is turned off.
your contactor that supplies power to the compressor has its contacts welded together and even if you turn up the thermostat and the coil that holds the contacts closed will de-energize,but with the contacts welded together this is no longer possible,you need to replace the contactor
Apr 16, 2010 | Fedders A6Q10F2B Q Chassis Room Air...
Air conditioner shuts off early.
Hi, thermostats is not problem , it's asking for cooling when it should, it's your condensing unit outside, if mechanics said, system is o/k. then it's location of condensing unit, check location of your condensing unit, in relation to direct sunlight, condensing unit best location is always a cool place, preferable away from direct sunlight, check to see, when unit is doing that, if it's expose to direct sunlight, that could be your problem, direct sunlight for long periods could cause the high pressure & temp. controls malfunction. or maybe system is not fully charge with freon, double check freon charge. if direct sunlight is your problem, build a shade or change location of condensing unit, good luck.
Aug 02, 2009 | Ruud UAKA060 Air Conditioner
Window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Jun 07, 2009 | Whirlpool ACQ189XM Air Conditioner
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
My Coleman Evcon AC unit ices up everytime I turn the unit on
If the AC unit doesn't have sufficient air flow to carry away the cold air then condensation and the extra cold air will freeze at the unit. good air flow is the solution. Change the filters, clean the unit by removing the covers and looking for pet hair/leaves/dirt inside the coils of the unit. and make sure the ducting is connected and not clogged.
Jun 05, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
