Question about Frymaster Dean SR142GN037 Deep Fryer
The pilot light on my Frymaster Dean SR142GN does not stay. I have had it for a few years now.
  • info74168 Aug 05, 2010
    Is there any maintenance that can be undertaken ourselves before we call in an engineer. The pilot light remains on if we hold down the dial but as soon as we take it off it goes out. Frymaster Dean SR142GN
  • Frymaster Dean Master
  • 8,220 Answers
The pilot serves two purposes: lighting the burner and heating the thermopile. In operation, the thermopile is in contact with the pilot flame and generates millivolts. The millivolt output passes through a normally closed high-limit switch and energizes the gas valve pilot coil, which in turn opens the pilot valve. The pilot light on my Frymaster Dean SR142GN does - f078045.gifIf the pilot flame is extinguished, voltage is lost to the gas valve pilot coil and the pilot valve closes.
Thermophile not only acts as a safety, it also puts out enough voltage to operate the valve. Therefore they cost a lot more than a standard thermocouple. Here is your manual coutesy of Partstown a leading supplier of rest parts. I highly recommend them.
Rate it or Hate it: f826ab1.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
  • 2,272 Answers
If the pilot fails to stay lit, depress the dial and re-light the pilot.But id still the problem then the thermostat needs to be checked. Also the gas valve needs to be checked. Check out.thanks.
  • raj somaiya
    raj somaiya Aug 05, 2010
    If that is the case then the dial needs to be checked,its getting internally short and causing the pilot light too go off.Actually the internal dial is turning it off. remove the dial and check.the units panel needs to be disassembled to remove the dial.
    As if the engineer comes ,he will check the dial and replace its internal connections that is causing the pilot to goo off as you release it.
    Thanks for keeping updated with your query.
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
Pilot light will not stay on
Defective thermocouple. It is the metal tube that is in the flame of the pilot light.
Jan 01, 2014 | Frymaster Dean Kitchen Appliances - Others
SR142GN , when working the fire will be stop suddently, but now we can't light it on at all .
Call our service tech, Ray... He might be able to walk you through a few things to try... I think I would need more info before I could just help online... Our number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, parts, smallwares, and ship in 1-2 days. Thanks, Susan REO
Sep 12, 2011 | Frymaster Dean SR142GN037 Deep Fryer
Hi, The pilot light wont stay on when I release the gas before swithing it to the on position. Can you help
check if the thermopile receives enough heat from pilot flame, if it does, replace the thermopile.
Mar 29, 2011 | Frymaster Dean SR142GP001 Deep Fryer
My pilot light will not stay lit. I have replaced the thermocouple and still will not stay lit. Can the valve be bad?
Make sure the thermocouple is deeper into the flame of the pilot light. It needs to reach a high enough temperature to produce a high enough voltage to keep the pilot light lit all the time. I do not think that the main gas valve is bad at all.
Nov 25, 2010 | Frymaster Dean SR42G Deep Fryer
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
I have a frymaster model mj35ssp cannot find where to light the pilot light at! Can someone please tell me
If you forward your e-mail address I will send you the Frymaster instructions w/ picture of where to light the pilot.
Rick
capt_rick1912@yahoo.com
Jul 21, 2009 | Frymaster Dean MJ35-SC-1 ''Standard'' Deep...
Dean gas deep fryer m# SR142GN
Thermocouple is getting weak. Replace the thermocouple with a new part.
Apr 21, 2009 | Frymaster Dean 2424G Deep Fryer
Kitchen Appliances - Others Logo
714 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
