Question about Weber Genesis Silver A Grill
Full propane tank - won't heat above 275 - Weber Silver A barbeque
  • 2 more comments
  • utting375 Apr 27, 2008
    Grill is 5 years old, new tank - flame is coming thru, but not hot enough to get temp over 175.
  • Anonymous Jul 20, 2008
    I have a new grill, propane tank says emptyon guage but feels full, appears nothing is coming out, how do I test/fix it?
  • boomdog02 Nov 18, 2008
    I have a platinum II series grill ...my gas tank is full yet I can't get the heat above 300 degrees...what's up?
  • Anonymous May 02, 2009
    i'm not sure i understand
  • 36 Answers
How old of a grill is your Weber Silver A?
Did the tank come with your grill?
Fireplace-girl
Posted on Apr 26, 2008
  • Kathy Williams Apr 27, 2008
    Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
    Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Weber spirit won't get hotter than 300. What's wrong?
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jun 19, 2014 | Weber Genesis Silver C Grill
My weber genesis E 330 thermometer never goes higher than 400 degrees F Why?
Jun 04, 2014 | Weber Genesis Silver B Grill
Very low heat even when temp. control turned to high. Propane tank is full and not leaking.
Change your regulator! You can get them at home depot or a hardware store!
Aug 21, 2011 | Weber Genesis Silver B Grill
I have a weber genesis grill. It did not heat up above 425 degrees at first and now it does not go above 300. This is with the searer on as well. Does this make sense to you? It is hooked up to a...
Was your grill originally set up for Natural Gas or did to convert it from Propane to Natural Gas? If so, where did you get the conversion kit? It may have been missing some vital parts.
If it was not a conversion, did the grill come with a natural gas regulator already installed?
Please advise... Thanks
Jul 18, 2011 | Weber Genesis Silver B Grill
I have a full tank of propane - grill will not ignite. I have a weber silver model
Hi, Check the igniter and also the gas nozzle that it is not plugged with grease. Clean up and try again. Make sure that igniter is working properly. Replace if nescessary.
Jul 09, 2011 | Weber Genesis Silver B Grill
I love,love,love my baby webber. I bought it when they first came out. I can only use the tall, blue propane bottle. I seen some where that they were using the short, wide, green one. My wire guide...
The easiest solution to this problem is to remove the screw securing the wire tank holder in place, and then just bend the holder a little bit wider so that it will fit the slightly larger 16 oz green tanks found in the camping section of most stores.
You can even buy buy a hose connector adapter for it so that you can hook it up to a large home barbeque type propane tank if you want. See the following consumer reviews of that unit for more details and ideas:
http://www.amazon.com/Weber-Baby-100-Portable-Grill/dp/B0000E6GHI
Thank you and good luck.
May 22, 2011 | Weber Baby Q Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
LOW HEAT WHEN ON HIGH
This can be caused by the safety valve in the propane tank. Most times this can be corrected by tuning off the valve on the tank, make sure all the controls on the grill are in the off position. Then turn on the tank valve and try restarting the grill. All the controls on the grill must be off, before reopening the tank valve. If that does not work try another propane tank.
Mar 14, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver A Grill Logo
2,087 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
