Question about Dishwashers
Dishwasher doesn't drain completely at the end of the cycle. kitchenaid - model kds18
  • 487 Answers
Filter or pump are obstructed. Clear out both and it will run. If not you pump is broken
Posted on Apr 26, 2008
Dishwasher does not function properly
Best way to troubleshoot would be to use a multimeter and measure the electrical voltage at the pump just before the pump is to activate, watch the multimeter display for a drop in electrical voltage, if it does drop to zero the electronic control board located within the door has failed.
Dec 22, 2013 | KitchenAid Dishwashers
Doesn't pump out olll the water after a cycle is complete
check drain hose for kinks,,check drain spout for connection blockage..if you cant listen for water going down drain in pump out cycles...remember most dishwasher are intentually not grounded
Aug 29, 2011 | KitchenAid Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher not draining completely at end of cycle
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 15, 2010 | KitchenAid Dishwashers
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwashers Logo
181 people viewed this question
Top Dishwashers Experts
