Question about Hunter 52" Ceiling Fan With Light And Remote Control
Hunter remote part #85095 - 02 Remote will not control fan speed or light. Another remote I have does control this fan so the remote is the problem. Battery has been replaced but still does not function to control the fan/light. NOTE: LED on remote does operate when keys are depressed. Additionally, I have reprogrammed this (faulty) remote to operate another working fan/remote, but it also does not control the second fan.
  • 10865 Answers
SOURCE: need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
Posted on May 31, 2009
SOURCE: Hunter Fan Remote Control Part No. 85095-01:
I had the same problem. I found that the reverse button needs to be pressed really hard. It now works but I need to press that button really really hard.
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
SOURCE: hunter fan remote 85095-02, red signal light glowing continualy
It's continually transmitting. My guess is there is a button stuck causing the unit to run down batteries. If no button stuck, you'll probably have to replace the remote -- it's a fulty transistor.
Charlie
Posted on Aug 25, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
Hunter Douglas Remote Control Button, Fan Off, doesn't work?
Undesirable interaction between wall and remote controls. Choose one method of control or the other and stick with it.
Feb 22, 2018 | Hunter Dryers
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
I just installed a hunter ceiling fan with light & remote control but the fan will not shut off or change speeds
Sorry for this::::You may not have the correct remote for the fan.
The fans are difficult to install.
Kudos to you,Sir.
Nov 13, 2012 | Hunter 52" Ceiling Fan With Light And...
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Feb 05, 2009 | Hunter (25417) Ceiling Fan
Ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Dec 28, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
978 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
