Question about Whirlpool Dryers
The dryer will not start. I replaced the on/off switch thinking that was the problem. The dryer is still dead. An old dryer I have works fine, so the problem is not electrical from the circuit breaker. What should be my next move?
  • Whirlpool Master
  • 1,606 Answers
Replace the thermal fuse . If the lint screen is on top of the dryer , remove the back dryer panel and look for a 1 " long white piece with 2 wires going to it . Disconnect the power cord from the wall , and connect these 2 wires togather . Then plug the dryer back in and press start . If the dryer starts , replace this thermal fuse .
If the lint screen is by the dryer door , remove the front panel and the lint screen and the lint screen holder ( 2 screws ) and behind the holder , you will see this white piece . Replace it ( cant turn the dryer on without the front unless you disconnect the belt to test .
Always disconnect the power when working with electrical appliances .
ALSO , if you can use an ohm meter , you can check for an open thermal fuse , which would be the easiest way .
Posted on Aug 05, 2010
We have a whirlpool dryer from costco that is 3-4 years old. It was working just fine and then when I went to switch the wash from the washing machine to the dryer it would not start. In other words the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 06, 2011 | Whirlpool Dryers
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
The dryer would not start, it was dead, opened and slammed the door shut, it worked fine. 2 days later it went dead again, sounds like the door switch, any ideas?
Sounds pretty good, actually. Insert screwdriver on either end of bottom/top panel and lift. Find the door switch and bypass it for a quick fix (just remember that dryer will operate when you open the door - not recommended if small children are present in the home). My advice is to replace the switch.
Nov 16, 2009 | Estate TEDX640JQ Electric Dryer
Dryer won't start 7yr old dryer, was working fine yesterday, today was making strange buzzing noise while running, stopped it to check, and now won't turn back on.DEAD
Sounds like a defective motor starter contactor. DO NOT continue to try to use the dryer or you'll burn the motor out. The motor starter is built into the motor, but most are replaceable without replacing the entire motor.
Could also be the motor, but sounds like the motor is stuck in 'start' mode and never goes into 'run,' which would be the classic symptom of a stuck motor start contactor.
Jun 14, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Buzzer will not shut off when load is done
If your dryer also starts without pressing the start switch, then the push to start switch
contacts are stuck in the closed position. Sometimes you can press the button on-off-on-off
quickly to unjam the contacts, otherwise replace switch.
Jan 12, 2009 | Maytag Dryers
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
