Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Black ink I did remove the label that was to be removed, When I print my test page only half of the type shows up, almost like it is stuttering.
    Problem Solver:
  • 12 Answers
You may want to do the ff. just to make sure your printer is physically functioning.
1. Disconnect the printer cable that is connecting printer to the computer.
2. Turn the printer ON by holding down the POWER button for about 3 seconds.
3. Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4. Press the Up or Down arrows to select NOZZLE CHECK. Press the OK button,
then press OK to print a nozzle check.
5. The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6. To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the Nozzle Check Pattern page does not print, prints out with gaps in it or some of the colors do no appear, then there is an issue with the printer. That means that troubleshooting is required on the printer prior to using printer on the computer.
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
according to the manual, goodluck!!!
Posted on May 09, 2008
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
Canon pixma iP1000 is skipping random lines when printing
Sounds like it's congealed ink on the print head. You can buy cleaning kits and do it your self. Relatively in expensive compared to leaving it into the shop.
Nov 16, 2017 | Office Equipment & Supplies
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black will not print
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page,. Load a regular paper. Then try to print a demo page If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 18, 2009 | Kodak ESP 5 Printer
Trouble with Designjet 110plus: Cannot get Cyan or Black to print. When I change the printhead, the machine does not recognize it for both black and cyan. Machine DOES NOT show error on any printhead or...
Hi Paula, first of all, take out the Continuous Ink System. Second, make sure that the new printhead are good and work propretl, try to get them in another HP 110, if their work good and at your HP not working good whitout your Continuous Ink System replace the carriage assesmbly, but before that verify tge tubes of ink. Good look
Aug 03, 2009 | HP Designjet 110plus nr InkJet Printer
Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Neither black or color will print..
remove and check cartidges it is quite possible that the cartridges must hve dried up.
Dec 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
