Question about Skil FactoryReconditioned 920501RT 85 amp Reciprocating Saw
How do i change the blade in a reciprocating saw?
  • 43,501 Answers
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Posted on Aug 27, 2010
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
How do i change blade on dewalt dw303 reciprocating saw
Open the yellow tab on the side of the blade guard and lift the blade out. Install a new on and close the tab. If the blade has been damaged, it may need to be pried off the locating pin at the attachment point.
Aug 08, 2011 | Dewalt DC385B 18v. Cordless Bare...
How do I change the blade on my recipocating saw?
There is a small lever on the right front side of the tool. Lift that up to release the blade and push it down to lock the blade in place.
Jun 23, 2011 | Dewalt DW304PK reciprocating saw kit with...
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do i CHANGE THE SAW BLADE
Hout40, holding saw as U would use it, is a "dog" on the right side, that U pull out.
If U turn it around and look at the other end ( with the blade end) U can see the "dog" work the inside, that releases the blade. HTH, JoeB
Feb 19, 2011 | Dewalt 18v Dc385 Reciprocating Battery...
How to change the blade
look at front off saw , where blade is,there is a hex (allen) bolt, screw, or a lever on the side of saw
Apr 06, 2010 | Craftsman 8.0 amp Reciprocating Saw
Skil FactoryReconditioned  920501RT 85 amp Reciprocating Saw Logo
138 people viewed this question
Top Skil Saws Experts
Lawrence Oravetz
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
