Question about Maytag Portable Air Conditioner M6P09S2A
Maytag 9000 btu - model m6p0952a - serial cs93788 - cuts off every 30 minutes if you empty water in hose it will cut back on - is it suppose to have a pan in it somewhere the hose is on the side of unit-
SOURCE: Exhaust fan running slow
I JUST BOUGHT A 9000BTU PROTABLE AC MY QUESTION IS IF I REDUCE THE EXAUSTE FROM THE ORIGINAL 3" TO 2" WILL IT BECOME A PROBLEM WITH THE AC OR MALFUNCTION
Posted on Jul 02, 2009
  • 233 Answers
SOURCE: Unit not blowing exhaust!!!
http://safemanuals.com/brand-user-guide-instructions-owner-manual/MAYTAG, this may help you locate the issue. there may have been some degris that is keeping the blower cage from turning, or the cage may be damaged.
Posted on Jul 19, 2009
SOURCE: 9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Posted on Aug 18, 2009
  • 306 Answers
SOURCE: water leaking from Maytag M6T12F2A is this expensive to repair
The drain hole is likely clogged with lent and trash. Make sure it is level or leaning dow a bit on the back side. I had to drill five holes in the bottom rear of my old window unit to stop water draining down the insdie wall. Make sure you dont drill into a usefull component of the AC or kiss it goodbye.
Posted on Aug 22, 2009
bobicehouse
  • 1524 Answers
SOURCE: # of BTU's
24,000 BTU's
Posted on Jul 25, 2010
Maytag bravos x econocserve wont go through all the cycles and then you have to select the drain and spin to finish the clothes
You may be over sudsing the machine and it thinks the water is not drain and stops. Run a empty load on a cold water cycle and not hot water. then cut back on the soap. if you use fabric softener the cut back even more.
Feb 01, 2016 | Maytag Washing Machines
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
After about 10-30 minutes after cycle is finished there is water around and under washer
Your discharge hose is leaking. Check the hose itself, of course (for hoses), but the problem is most likely a loose connection of the discharge hose to the discharge outlet.
To inspect these items, you'll need to remove the back cover of the unit
(typically 11/32-in nutdriver), and follow the discharge hose to the discharge outlet. You may find that the hose clamp needs to be replaced, or that the
end of the hose is deteriorated, and needs to be cut off an inch shorter, and the hose clamp re-applied.
May 22, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Have a maytag washer model lat9306aae and it will fill right the first time but when on the rinse cycle it wont fill up keeps running out ?
Check the drain hose behind your washer. If if is too low you will get a siphon and the water will run in and not fill up the tub. The drain hose is supposed to have an anti-siphon valve / kit on it if installed correctly but not always. Lift the drain hose until the end elbow is nearly even with the bottom of the top panel lip.
Any local appliance part center will have this Siphon Break Kit:
http://outlet.whirlpool.com/-[285834]-300125/285834/
There is a rubber diaphragm valve in the top of the "T" that opens to introduce air into the drain hose to prevent a Siphon. Installation is simple. Lift your drain hose up vertially, Make a cut 4 inches from the bottom of the top panel. Install the T with the rubber end UP and connect the elbow you cut off to the T oulet and drain.
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Washing Machines
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
We have a 9000 btu portable frigidare air conditioner, we are constantly having to manually drain the bucket even with drain pump hose attatched. Is it possible tat the drain pump is broken? Occasionally...
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
sounds like the compressor is turning off cause of high pressure. check the coil that the exhaust hose connects to, if dirty clean it. if the fan is not blowing enough air threw the coil the unit will build up high side pressure and cut out, but will turn back on when pressure drops. if that dont help, maybe the fan motor is bad or needs taken apart and oiled.
May 31, 2009 | Maytag Portable Air Conditioner M6P09S2A
User manual
I have the same unit, we've used it most days in our office since beginning of April and it's just cut out. I removed the drain plug at the base of the back and drained out about 1 litre of water. It's now working perfectly again. My guess is depending on the humidity it should run about 1 full month before emptying
Hope this helps
azzymodo
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
221 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
