Question about Manitowoc Refrigerators
I have SD0452A model Manitowac ice maker. We put it on a cleaning cycle. Is the yellow light on top a cleaning cycle light. We need to stop cleaning now it's been cleaning for more than half an hour. How can we break cycle and go on to making ice
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 210 Answers
SOURCE: Ice maker not producing ice
What you can try to do is put the ice maker in test mode. Press and hold the ice size button, on the ice maker itself, for 5 seconds. It should cycle through and this could reset it.
Sgt 48
Posted on May 31, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
tborn6
  • 700 Answers
SOURCE: ice maker not working
you need to check the inlet screen on the solenoid down below for blockage, also make sure that the freexer is cold enough
Posted on Dec 26, 2008
Model No. unknown (believe it's a CLR-5+ years old with manual switch for on/off/cln cycles) will run in clean cycle, but stopped making ice. Ran cleaning cycle when it stopped making ice - worked per
After the cleaning cycle, if you drained the tank to get rid of the cleaning/descaling solution, you will have to refill the machine for the initial start. The normal freeze/ harvest cycle will normally fill the unit after the initial start. I have seen several ice makers with this same initial problem.
If this is not the case and your reservoir is full of water, then check water supply to make sure water will flow all the way into the reservoir. Sometimes the makeup water solenoid fails and need replaced. So if cleaning cycle works and fills, solenoid operated water valve is not the problem. If would mean some electric component is not working. The on/off/clean switch not sending on signal. The board, which is located under the top panel of the cabinet, may have a bad contact on the board. Another possibility is the water level sensor may not be in contact with the water. Most units will not start if the water sensor is not in contact with the water level. It normally looks like a metal probe and has a wire connecting to it to the control board. Any parts can be found by taking your model number to Searspartsdirect.com and can be ordered using a credit card and be delivered to your home.
Hope this helps
Jan 27, 2015 | U-Line Icemaker
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
Pump on manitowac ice maker hot to the touch
sounds like the motor has seized or the discharge is bocked and the motor is running but nothing is moving
Jul 28, 2014 | Garden
Reset clean light
Did you clean the machine? When you went through the cleaning steps it should have cleared the clean light. I will tell you what to push first Remove the front cover. If the machine is operating then push and release the harvest button. When the machine completes the Harvest cycle it will stop. Push and release the OFF button. Push and release the clean button. The yellow clean light will blink and display will show C. The machine will drain the reservoir and refill it. Go into the next step when the reservoir has filled. Allow the the ice machine to circulate water for at lest 10 minutes. Normally this is when you would add your cleaning solution but i take it you have already cleaned the machine. Now push and release the Clean button again. The yellow Clean light will be on continuously and the machine will drain and refill the reservoir repeatedly to purge out the ice machine. Now Allow the drain and refill process to continue for at least 20 minutes. Now Push and release the OFF button. The clean cycle will stop and the display will show 0. Now push and release the on button. This should have cleared the yellow clean light. Now with that out of the way if it did not clear it then you will need to replace the control board. The machine will steel make ice with no problem and you just clean the machine every 6 mounts. The yellow clean light is just to remind you that it is time to clean the system. The board is quite costly.
Apr 24, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Manitowac Series 150, not producing much ice, cycles itself off.
Use a fan to try helping it stay cooler but make sure coils are clean and refrigerant is not low if it has a temp setting turn it down
Nov 06, 2009 | Manitowoc MAN-KF3 Koolaire Freezer reach...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Top freezer ice maker not putting out ice
We shut down the freezer for 12 hours and the ice melted in the pipe. Thanks
Jun 21, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrigerators Logo
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
