Question about Gaggia Carezza Espresso Machine
My Gaggia Carezza Espresso machine served me well for about three years. There is is problem now. The machine does not turned ON. It is dead. Is there is hope? What does it takes to repair it? Is it a fuse issue?
  • 4,323 Answers
Hi
Please check for all the electrical connections inside the coffee maker. Also check whether all the components inside seems fine and not burnt. Please check these pictures, they'll help you--
Picture 1
Picture 2
Picture 3
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
Replacement for Gaggia Carezza ON switch?
It is a standard switch, so you can repalce it, as long as you know what you are doing
Aug 19, 2012 | Gaggia Carezza Espresso Machine
'on' switch on Gaggia Carezza not working
Usually it is the switch itself that has failed. Order the switch from your appliance repair/supply business and replace the item in the machine. A lot of these switches have plastic 'ears' that need to be pressed in to release the old part and the wire connections are usually 'push-on'. Some that are held on by a formed metal clip usually require breakage of the clip to release the part and the new switch should have a replacement clip. Hope this helps!
Feb 14, 2010 | Gaggia Carezza Espresso Machine
I have a Gaggia Carezza machine that is about 3 years old. Yesterday, the power switch seemed to have some resistance when I turned it off. I also smelled a burning plastic smell. Today, the switch seemed...
The description sounds like the switch has failed due to it's internal contacts arcing. I have a like problem with Mary214 that is ongoing. Please follow that thread to find your fix.
Dec 27, 2009 | Gaggia Carezza Espresso Machine
Cannot find replacement for the Gaggia Carezza powerswitch anywhere. Model discontinued. Want to jump the wires so that it is on when I plug it in.
Here is a list of gaggia dealers, one of them might have it, if not check with radioshak.
I do not have it so you can skip me.
Oct 09, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza will not turn on
look on top of the boiler you will find a microthermo  it trips when the machine gets too hot and you are going to have the replace it. now i posted the fix in a form for the same thing. and where to get one.
Apr 20, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine burned out
as i understand from your decriptition, you had temperatire rising in extreme point. termofuse should worked but it didnt, i advice you to change all 3 and some seals:
  1. Thermofuse
  2. Thermostat water L=107C
  3. Thermostat steam L=145C
  4. Gaggia gasket 6-pc. Kit (during changing them you can clean boiler too)
here is the link for diagram:
http://www.partsguru.com/user/Carezza%20diagram%20and%20parts%20list.pdf
here is the link for parts:
http://www.partsguru.com/GaggiaCarezzaespresso.html
Apr 03, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza not turning on
I just bought a broken Carezza for my office (and hacking)-- the owner said the power switch only worked when he held it down hard.
Taking it apart, the main power switch-- a DPDT automotive-style unit-- is broken on one pole-- the wire connectors are slightly melted and darkened, and the switch has melted, discolored plastic around the metal tabs.
A new switch should bring it back to life, and I'll install a removable power cord and 15A fuse for niceness/safety-- the switch is rated for 20A at 125VAC so shouldn't have fried.
Feb 16, 2008 | Gaggia Carezza Espresso Machine
Gaggia Carezza doesn't brew
May need priming -- follow the directions in the manual.
Jul 01, 2007 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine Logo
35 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
