Question about Haier DM30EAL Dehumidifier
A PUDDLE FORMS UNDER MY DEHUMIDIFIER WHEN IT IS RUNNING, THE BUCKET IS ON THE IT IS IN PLACE. IF NOT IN PLACE CORRECTLY THE DEHUMIDIFIER WILL NOT RUN.
3 Suggested Answers
wilderbeest
  • 40 Answers
SOURCE: A PUDDLE OF WATER FORMS UNDER MY DEHUMIDIFIER WHEN
Dehumidifiers have a container that holds the water the the unit extracts from the air. If that container is full or not placed correctly, the water will leak out of the unit.
Posted on Aug 05, 2010
  • 1340 Answers
SOURCE: My dehumidifier leaks and not shut off. The
I don't have a Haier but I have a dehumidifier which has a float and when the float get to a certain point,it activates a switch for auto shutdown.If yours has the same setup,the switch is probably bad.
Good luck! Greg If not,let me know.
Posted on Aug 16, 2010
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
Not running- CH 24 code on the Humidity setting & empty bucket red light flashing even though bucket is empty and in place correctly
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
Aug 22, 2011 | LG Dehumidifiers
I have had the Frigidaire dehumidifier model FDB5OR1 for four years. Starting last year, the unit would occasionally continue to operate after the bucket was already full, resulting in puddles on the...
The faulty float valve is almost always the problem, based on what you described. It is a replaceable part, but you may have to but the entire bucket assembly. Generally, they run around $50.00. However, not all parts are still available for that model, even though it's only 4 years old.
If you want pursue finding the float valve or a new bucket assembly, the best place I've found is online is Appliance Factory Parts http://www.appliancefactoryparts.com/search/index.php they carry parts for just about any appliance you can think of.
Or Frigidaire Parts Select
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Frigidaire&Term=frigidaire&gclid=CIfU4u28vqkCFcPd4Aod6CC5hQ
I hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Frigidaire FDL50R1 Dehumidifier
I have the 25 pint unit and it leaks underneath the bucket. Water does get pulled into the bucket but when running water leaks out at the bottom and puddles on the floor. The bucket has been checked for...
If the unit is leaking under the bucket and you haven't been able to find a crack or hole in the bucket. The bucket may not be properly inserted in to the dehumidifier. Remove the bucket, empty it and reinsert it into the unit making sure that it fits in squarely (Top to Bottom).
If the above doesn't correct the problem, the drain tube to the bucket may be partially clogged. To check this, you will need an 18" long, plastic Zip Tie or something similar. But NO wire coat hangers. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and you will see a drain hole or tube at the top of bucket cavity. Carefully insert the Zip Tie and continue to push it in unitl you reach the bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, slowly remove the Zip Tie while rotating (twisting) it. As you reach the end of the Zip Tie be prepared for some water to follow.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool 25-Pint Dehumidifier
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
My dehumidifier leaks and not shut off. The bucket is full, but the unit still runs and I notice water puddling under the unit and my rug is wet around the dehumidifier.
Aug 16, 2010 | Haier HDN655E Dehumidifier
A PUDDLE OF WATER FORMS UNDER MY DEHUMIDIFIER WHEN IT IS RUNNING.
Aug 05, 2010 | Haier DM30EAL Dehumidifier
GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 19, 2008 | Dehumidifiers
Haier DM30EAL Dehumidifier Logo
44 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
