Question about Microsoft Xbox 360 Elite Console - Black
My son pulled my xbox off of my tv stand, the front cover popped off and the hard drive popped out. it still runs just fine and i was wondering if i will have future problems now that this has happened?
  • Microsoft Master
  • 4,806 Answers
There is a possibility that you could experience problems down the line but if its still working properly and still loads from the hard drive then you are probably one of the lucky people that have got away with it.
Problems you could encounter later is the dreaded red ring of death which has nothing to do with the drop but rather bad design of the X-Clamp on Microsoft's part.
Main problems are E errors, Open Tray errors and sound but no video.
Regards.
Posted on Aug 05, 2010
What is code e68
I am assuming you mean for an Xbox 360? If so, it means you have a hard drive issue. Many times this can be resolved by reseating the Hard drive try this
Xbox 360 E console
Turn off the console.
Unplug all accessories connected to the front or back of the console.
Position the console horizontally.
On the right side of the console, locate the hard drive cover release near the back of the console.
Slide the release diagonally (down and toward the front of the console) while pulling the hard drive door open.
Jul 02, 2018 | Dryers
Error code E68 Meaning?
his may mean that the Xbox 360 has a hardware problem
Solutions
To resolve the problem, try disconnecting your console's hard drive. Here's how:
Xbox 360 E console
  1. Turn off the console.
  2. Unplug all accessories connected to the front or back of the console.
  3. Position the console horizontally.
  4. On the right side of the console, locate the hard drive cover release near the back of the console.
  5. Slide the release diagonally (down and toward the front of the console) while pulling the hard drive door open.
  6. Pull the tab to remove the hard drive.
  7. Reconnect each accessory.
  8. Close the hard drive cover before turning the console back on.
If the problem persists with the hard drive removed, you will have to get the console repaired
If there is no red light around the power button, reattach your hard drive.
If the problem persists only with the hard drive attached, order a new Xbox 360 Hard Drive
Jan 21, 2016 | Dryers
Have just added a hard drive to my son's xbox360 but it isn't recognising it. what should i do?
sir i think the way how you added a hard drive on your xbox 360 is not correctly... try this instruction on how to add a hard drive on your xbox360...
The Xbox comes in two versions, one with a hard drive and one without. Enhance game play and speed by adding a hard drive to cache the game data during play. Adding a hard drive or swapping out the original for a larger drive is easy and gives you as much storage as you could ever want.
Difficulty:Moderately Easy Instructions
    • 1 Select a hard drive with enough space to hold all of the games and media you wish to carry with you. Look for drives with 7200-RPM specifications for faster speed when loading and caching games.
    • 2 Format the hard drive to FAT64 using the Windows format utility. Drives larger than 32 gigs will require third party formatting software although Windows 98 is capable of formatting up to 127 gig drives.
    • 3 Turn off the power and remove all cables, including the audio, video and controller cables. Lay the Xbox on its side with the front facing you. Look at the left side and pull the hard drive cover away from the console gently.
    • 4 Place the hard drive over the Xbox hard drive bay with the tapered end towards the front of the console and the connector end toward the bottom. Connect the cable carefully and verify no pins have bent.
    • 5 Align the hard drive slot with the back of the drive and set it into place until you hear a click. Press the cover on carefully and connect all of the cables. Turn the power on and verify the Xbox powers up properly.
Read more: How to Install an Xbox 360 Hard Drive ' eHow.com http://www.ehow.com/how_4392665_install-xbox-360-hard-drive.html#ixzz1OyZkTiai
if you think this help you please rate me sir thank so much...
Jun 11, 2011 | Microsoft Xbox 360 Console
I bought an xbox 360 lastnite for my son he puts the game in and when he goes to play the game it pops up... but it says you need to be connected to a hard drive how do i fix this problem??
Sorry, but many games require a hard drive. if you bought the 4 gig package, it didn't come with a hard drive just an internal memory unit. There is no way to circumvent this.
Feb 11, 2011 | Microsoft Xbox 360 Console
Hiya I my son can't get on xbox live but his
are they both connected by wireless or is one connected by ethernet
Mar 26, 2010 | Microsoft Xbox Console
In order to connect to pc it says to remove the harddrive from the xbox but i can't see where to open it and i have no manual. didn't want to proceed and break something.
The harddrive is on top... the thing is kinda hidden its a oval shape... you press down on it.. then you pull up on the harddrive...(when the xbox is standing up the harddrive is on top)
Jan 11, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console
On the left hand side of the console, or the top if it is standing upright, is a grey panel with holes through it, you can remove this panel and this is where the hard drive is inserted. You can purchase a hard drive from any xbox 360 games retailer or also online.
Aug 24, 2009 | Microsoft Xbox 360 Console
I was wondering how to get my back seat out of my 99 ford taurus i dropped my diamond earring back there and need to takt out the seats
get in it put your knees on the front of the seat and push hard while picking up on the bottom with you hands!!! it will pop up
Apr 16, 2009 | Ford Taurus Cars & Trucks
Xbox chirstmas lights
you have to first pull off the front faceplate. it will pop right off. then take the harddrive off. pop the two grey ends off. Now take the back and with a small flat screwdriver push it into the small slots till you here a click. do that all the way across the back. then do it to the front. there easier clips in the front. pull the bottom cover off. next take all out all of the screws. i believe T10 and T8 torx bits. then carefully flip it back over and take the top off. make sure you pry the cd drive button off first. Fom here you should be able to diagnose whats wrong or whatever you needed to do.
Apr 19, 2008 | Microsoft Xbox 360 Console
My xbox 360 disk draw keeps opening and wont let me play games?
My problem was the magnet that is supposed to be in the black rotator that the DVD is placed had come out and was sticking to the top of the DVD drive lid... I opened up the XBOX 360 by removing the hard drive on the top first then on the sides of the XBOS you will notice air holes but if you look closer looking from the front of the box on the right hand side you will notice there are more holes then the left and side. I will try to put everything in steps and hope you understand them
1 - Removed the hard drive from the top
2 - Starting from the back pushing a pen in the side holes on the right hand side to unclip the Gray cover
3 - Do the same on the bottom to remove that Gray cover as well.
4 - Unclip the front white face cover and remove it
5 - you will see 4 cover clips on the front holding both side of the case together "unclip them BUT don’t force apart" there is more on the back
6 - Unclip the back by pushing the pen point in all the 7 small holes in the back THEN you can pull the cases apart
7 - Remove 6 long screws from the bottom then take the othe side of, Unplug the cables from the back of the DVD drive and lift it out away from the XBOX
8 - Unscrew the 4 side screws of the DVD drive and take the top cover off.
9 - Take the magnet of the top cover from the white plastic
10 - Use some very good adhesive glue on the black rotator wheel (not to much) wait for the glue to part dry for 3 or so minutes then place the magnet in where it belongs
11 - Leave overnight to dry (don’t try and hurry the glue or you will be doing this again.
-- ** now revers all the steps from 6 till 1 to put everything back together ** --
Mine is fixed now and I hope this worked for you (I did get it working sometimes by just keep opening and closing the draw) but this fixed it for good and now all is working well again
Sep 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console - Black Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
