Question about M-Audio Audiophile 2496 Soundcard for Computer Recording/Playback
Reload this Page Pinout diagram needed for M-Audio 2496 DB9 connector
Driver for PSC VS1000
Hello, you asked the driver behind the times reader PSC VS1000, succeeded ?, you could send me, you have the pinout diagram of the serial cable rs232 db9?
hug,
john son
Mar 06, 2014 | PSC VS1000 & VS1200 Accessories - P/N...
I am looking for the pinout diagram for a Boss BV9560b in dash DVD player. I don't have the wiring harness and have no idea what pins connect to my factory connector or what kind of plug connector I...
did the same thing no harness but went to boss webpage got the number and called said it cost 25.00 with shipping by the way on there support page is a download for there parts form order you'll need it
hope this helps
Sep 06, 2011 | BOSS AUDIO SYSTEMS BV9560B Car Video...
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
Mar 03, 2010 | Alcatel Newbridge MainStreet 3612...
Wiring diagram from db9 to rj-11 to open cash drawer
This IBM page seems to have the information needed to wire a DB9 to RJ11 for a cash drawer:
http://www-01.ibm.com/support/docview.wss?uid=pos1R1003522
Jan 12, 2010 | Adapters.com RJ11 / RJ12 (6 Conductor) -...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
What is the right rs232 cable to connect a Denon 3808CI reciever and a Phillips RFX9600 serial extender
OK LOOKING AT THE SPECS FOR THE EXTENDER YOU DO NOT NEED TO WORRY ABOUT THE SERIAL CONNECTIONS, WHEN USING THE SERIAL CONNECTIONS YOU NEED RS232 CODE STRINGS TO CONTROL THE DENON OR ANYOTHER DEVICE THROUGH THIS EXTENDER USING THE RS232 CONNECTIONS.
IT LOOKS LIKE YOU CONNECT AN I/R EMITTER FROM AN MINI JACK I/R CONTROL PORT ON THE BACK AND THE OTHER END TO THE I/R WINDOW ON THE DENON
Feb 27, 2008 | Denon AVR 3808Ci Receiver
JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Mar 29, 2007 | JVC KD-S640 CD Player
M-Audio Audiophile 2496 Soundcard for Computer Recording/Playback Logo
142 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
