Question about Old Town Tripper Canoe (17' Royalex(R))
My tripper has the bow worn down by constant running on ground and hitting rocks. What materials do I need and how do I repair it?
    Novelist:
  • 269 Answers
Any dealer in white-water canoes, and most others, will have kits with kevlar skid plates to install bow and stern for just this reason. Be sure to do this, and do a good job so you can keep water out of the laminated layers.
BTW: you can paint in with Tremclad!
Posted on Jan 26, 2011
    Problem Solver:
  • 12 Answers
Try bullseyetradingpost.com they were working on a skid plate for poly plastic canoes e-mail and ask for help! they were very helpful with solving a few seat problems for me.
Posted on Aug 14, 2010
My intermatic t103 timer is connected to my outdoor lights, why do the lights constantly stay on?
1) 156T1978A on-off Trippers are worn down? Clock dial is not rotating because WG1570 clock motor is bad.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
2) Add comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 10, 2013 | Hardware & Accessories
Everytime I put the pre-sets for the timer, it does'nt keep time. COuld you assist me or provide me with someone who can repair?
I can assist you.
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
The 'pre-sets' are confusing.
Do you mean tabs or trippers?
Tork 8601 is a 60 minute cycle timer.
The dial should make 1 full revolution each 60 minutes.
Trippers or tabs located on dial are pushed up or down to set on-off schedule.
If dial is running slow, then clock motor has gone bad.
If dial is running on time, then trippers are worn down or timer parts are worn down.
Either case when timer stops functioning, buy a new timer for $110.
If the clock motor was available, you'd probably spend $60 for the motor.
http://www.farmerboyag.com/time-clocks/23080024.asp
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Same Intermatic timer is C8865 for $88.35
http://www.amazon.com/Intermatic-C8865-1-Hour-Repeat-20-Amps/dp/B000GHKO8K
Jul 18, 2011 | TORK Variable Cycling Timer 8601
Lights come on for two seconds then turn off
Check that wire is attached firmly to A and B terminals.
Check that outlet does not have loose wire.
Tripper might be worn down so it does not fully push the on-off lever.
Push tripper all the way down so it will contact the on-off lever.
Check that lights work with override switch.
If lights turn on-off with override, then set timer to ON, buy cheap plug-in timer, and plug power pack into cheap timer.
Generally, there is not good news if power pack stopped working.
Trippers can be replaced, but there are no repair parts for power packs.
Following link has troubleshoot checklist and replacement tripper information, and 5-year warranty info:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
After laying my bike down the speedometer stopped working the key symbol on the speedometer stays lit up and the turn signals stay lit constantly and when I turn the turn signals on they don't blink. Where...
Do you have the security system on your Dyna? What side of the bike hit the ground? I would start by looking at any obvious areas that received damage.
Does the engine start and run, or does it try to start, but won't keep running?
If you have the security system, it may need to be put on the computer at the H-D shop and be reprogramed. If the bike hit the ground hard, the module may need replaced.
If you received damage to the controls on the handle bars, I would check for wiring damage in that area.
Everything you mention as not working is electrical, and, if you have the security system, it all runs through there.
I find that the owners manual helps some, but sometimes it takes a phone call to a shop.
Apr 10, 2011 | 2004 Harley Davidson FXD - FXDI Dyna Super...
I have the ML300RTW transformer. Just need to know about the trippers, one red and one black. Which one turns the system on and which one turns it off.
Here's how to check your power pack: Connect everything and set trippers randomly, and then manually rotate dial clockwise and watch when lights turn on-off, this will let you check if you have trippers set correctly.
As time passes, the dial rotates, and trippers push on-off lever that turns low-voltage lamps on-off.
If trippers no longer work, it's because trippers are worn down or the lever is worn out or the electrical contacts have burned. And the clock motors slow down and burn out.
There are no repair parts for low-voltage transformers. No trippers or timers.
"Harry" wrote to fixya with idea when timer no longer works: he bought cheap plug-in timer, set power pack to override, and then plugged power pack into cheap timer.
Since there are no repairs for low voltage transformers, I found tips that might save money:
The reason I add tips now, before power pack needs replacement is some fella wrote fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 31, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
The on/off lever on my t103r has worn down , and the timer dial posts no longer switch it on and off . can i replace that part . thank you , Don Henrichsen / Sherman Oaks , California
I think trippers have worn down.
Tripper are made of softer metal than on-off lever.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
That being said, if you have gone through several trippers and timer is old, then on-off lever can wear out.
Except for 125V clock motor and on-off trippers, there are no repair parts for T-103.
Buy new T103 and swap mechanisms without changing box.
That way you don't have to buy more expensive T-103R outdoor timer.
Mechanism snaps out with metal spring located at top inside box.
I purchased T-103 last week from Lowes.
Surprised that Lowes carried all 3 T-100 series timers:
T-101 125V with terminals A 1 2
T-103 125V with capability of controlling 120-or-240V circuits with terminals A 1 2 3 4
T-104 240V with terminals A 1 2 3 4
Nov 28, 2010 | Intermatic T103R 120-Volt 40-amp Timer...
Not turning itself on and off. tigger are set clock is running. light are on 24 hours. model no T101 diana or shannon
1) The on-off tripper pins might be worn out. Buy new pins
Do you need new pins?
2) The manual override will click on and off with timer. Watch if manual lever is moving to OFF when timer is off ... and moving to ON when timer is on.
3) Timer might be worn out. Click manual override lever back and forth.
Is manual override loose? Or does it click crisp ON and OFF? This test would indicate general wear on timer. If manual override is loose or broken, the tripper pins may pass right over without tripping lever.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/images/WH-lever-005-500.jpg
http://waterheatertimer.org/images/Back-of-WH40-2b-500.jpg
4) If manual override clicks on and off with timer, and lights stay on, then there might be a short between timer and lights.
Test for short to ground. Turn off power. Inside timer box, disconnect ground wire going to light. Do not disconnect ground wire unless power is off. Turn power back on. If lights are off, then the wire going to light is bad, or a light fixture is bad.
Caution. If there is a short, do NOT touch light fixture when power is on.
Sep 17, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Torn bow
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
May 10, 2010 | Advanced Elements Advancedframe...
Old Town Tripper Canoe  (17' Royalex(R)) Logo
170 people viewed this question
Top Old Town Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Old Town Boating Expert? Answer questions, earn points and help others
