Question about Brother MFC-8840D All-In-One Laser Printer
BROTHER MFC8840D IS THERE A WAY TO SHOW THAT I SENT A FAX TO A SPECIFIC PHONE NUMBER AT THE END OF MAY?
  • Brother Master
  • 5,523 Answers
Possibly. The Fax Journal has the last 200 faxes (incoming or outgoing). Press Menu then select Fax (up and down arrows). Press Set, and use the navigation keys until Setup Reports or Report Settings appears. Then press Set and use the navigation keys to find the Act. Interval or Journal Period. Press Set again and a length of time for the Journal (anything but off). Press Set again. (If you use the 7 day count-down, you will get additional queries for day of week and time of day for the start of the count-down.) Press Stop/Exit and the Activity Report will print when 200 faxes are in memory, the memory is full or the desired time frame. (The setting of 50 faxes will print at every 50 faxes.) After printing the report, these entries will be deleted.
I hope this helps.
(if the report was already generated, you won't get the old entries. Similarly if the memory was cleared after an Out Of Memory error, you won't find this entry. If Fax Storage was on, you may be able to actual get the original Fax. Menu > Fax > Remote Fax Opt > Print Fax or Print Document. Then Start and when all stored Faxes print hit Stop/Esc.)
Posted on Aug 05, 2010
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
I dont know who to change the phone number on the out going cover page so the receiver has a fax number to send back papers sent
If you don't have a User's Guide, go to the Brother web site and download it. But as a quick fix, you can access the menu function and navigate to settings and find the outgoing fax number place. Then you can change the number and name as you desire.
Jan 24, 2010 | Brother IntelliFAX 1570MC Plain Paper Fax
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
Same fax sent out at same time to two phone numbers and fax now has same file number? error?
No error. Same fax is same original(s), even if sent to 10 different ph. numbers. I'm assuming this was accomplished using group dial? The report should show that file number associated with 2 different locations.
Oct 15, 2009 | Toshiba DP-85F Fax
Adding and deleting into and out of group phone list
Group setting where? In the driver? In the menu in the machine? In some piece of software?
Are you refering to the name and phone number people see when you fax them?
Please be more specific.
Changing the name and phone number for faxing operations is covered in the owners manual. If you can't find the manual, there should be a copy on Brother's Web Site at www.brother.com
Dec 28, 2007 | Brother IntelliFAX 4100 Laser Fax
The brother Intellifax 2800 intercepts other faxes
Make sure that the proper phone number is installed in the fax.Also that they are not sharing the same common line.
Oct 17, 2007 | Brother IntelliFAX 2800 Laser Fax
Finding a fax confirmation in memory
you can get a prinout of last certain faxes received or sent(appx 20), if the number is among them, it's your luck happy faxing omnipresent
Sep 20, 2007 | Brother MFC-8220 Fax
Brother fax 930 machine
I would try sending to another source. If the document goes threw the machine and you get a confirmation report saying it was sent, then it was sent. The person on the other end may be having trouble with their machine as well.
Aug 03, 2007 | Panasonic KX-FP85 Plain Paper Thermal...
Brother MFC-8840D All-In-One Laser Printer Logo
229 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
