Question about LG DLE2532W Electric Dryer
Our LG Dryer Model DLE8377NM is not working every 4 or 5th time we try to use it. The outlet and the dryer cord have been checked and there is power to the machine. If we reset the circuit breaker to the dryer outlet the dryer will work again for 4 or 5 more times.
jsrock516
  • 5911 Answers
SOURCE: Electric Dryer
If your dryer came with a 4-prong plug, do not change it. For the very reasons you quoted with the article, you may screw up the 110v accessories required of your appliance (like the clock or digital display). It is best to change the household outlet to a 4-prong type. Just make sure your wiring is correct. You will need a neutral on the 4th leg, which means you will probably have to run new wiring from the outlet to the distribution panel.
Posted on Jul 01, 2007
  • 27 Answers
SOURCE: My LG dryer will not power up
check the door switch or the actuator for the door switch. hope this helps.
Posted on Nov 02, 2007
SOURCE: LG DLG2532W Gas dryer problem
I just purchase my LG front load gas dyer and am wondering what types of problems to expect and what people are doing about it....
Posted on Feb 19, 2008
rickzilla
  • 706 Answers
SOURCE: How do I remove the
Hello alloyd1455,
Please find a link for the service manual for your dryer and note page 26 and up discusses how to open up and gain access to the inside compartment.
Hope this helps
http://136.166.4.200/contents/Laundry/DLE0332/DLE0332_Service_Manual.pdf
Regards,
Rick
Posted on Dec 01, 2008
  • 686 Answers
SOURCE: where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
Posted on Mar 06, 2009
My Electrolux front load dryer model#EIED55HMD0 isn't getting power from outlet , has proper voltage and power at outlet,; checked door latch , power cord , vents , performed factory reset and limiter. Any...
Hello Sarah,
Check the power cord connections at the dryer terminal itself. You'll need to unplug the dryer, then remove the cover where the cord enters the dryer. It is very common for these to burn and break due to loose connections.
Did you also try a hard reset?
Not sure if this will help, but found this video
How to fix an Electrolux washer that has no power or frozen screen
Jan 10, 2018 | Electrolux Washing Machines
Why wont my LG Tromm DLE8377NM dryer spin
does the motor run? if it does then your belt may be off or broken. check it and replace if needed.
Jun 08, 2014 | Whirlpool LGQ7030KQ Gas Dryer
LG Tromm DLE8377NM check filter but filter is clean
You say lint hose is disconnected. Are you referring to the exhaust vent to the outside? I would suspect this vent is clogged or a vent flapper outside may be stuck shut.
Feb 14, 2012 | LG Dryers
I have a LG DLE8377NM dryer that has stopped working. the timer seems to work but the drum will not turn. is the motor bad?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 15, 2010 | LG Dryers
I have an lg dryer model dle2532w that comes on for four seconds, then shuts off, then comes on and repeats this cycle, i replaced the thermistor and it still does the same thing. Thanks! David
You have a power issue with the power cord or the plug but it's hard to determine because this is a 220v unit. You will need an electrician to check the plug outlet to make sure it's working properly.
Good luck
Sep 29, 2010 | LG DLE2532W Electric Dryer
LG DLE8377NM dryer is working but not heating, cleaned out all the lint and the vent lint, still no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 22, 2010 | LG DLE5977 Electric Dryer
My dryer won't turn on what can i do?
Check house fuses or circuit breaker.
Ck. power cord and power outlet for signs of arching an replace if needed.
Ck. power cord at dryer side and make sure the ends are not burnt. Unplugged of course.
If all is ok call for service.
Jan 16, 2010 | LG DLE2532W Electric Dryer
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
43 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
