Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525, Lamp light came on replaced lamp, old lamp looked good and ohmed OK, Replaced Lamp board. This happens with old and new parts. Unplug & plug in power. Timer Light fast blinks for about 50 sec. Then all lights out. Power on timer light steady for about 30 sec. Lamp lights for about 15 sec. Lamp go's out The Red Lamp light comes on steady. No getting any flashing light codes.
  • Mitsubishi Master
  • 11,800 Answers
This is a known problem on this model of tv, the power source is going in protected mode because it detects an excessive current on one of its exits  - usually because the filtering capacitors have aged or completely failed. The power board must be repaired - the capacitors replaced, all the diodes and transistors checked.
There are companies that will do it for you like
http://www.moduslink.com/aftermarket/repair-remanufacture.cfm
Give them a phone for a quote, it will be around $100.
If you decide to do it yourself start by replacing all electrolytic capacitors, whatever of their status.
Posted on Aug 05, 2010
WD-62525 went dead. Can a burned out lamp cause this?
No, a burned lamp would cause the power source of the tv to go in reduced mode and that would be clearly identifiable by the blinking lights on the status and lamp indicators.
If the tv is dead (no lights whatsoever)it means that the power source has failed completely - this is a big defect, that must be investigated by a pro: the origin of the failure must be found and the faulty part replaced replaced or any new part you just put in blindly will be instantly fried. At least the power source board will have to be replaced and that will cost you around $250.
Jan 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Won't work after replacing lamp
Ballast board might need to be replaced,it is what powers Lamp on. Go to Encompass Parts Distrubtion they will list Parts/Prices for this Set.1-800-638-3328
Mar 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp 2 weeks ago. lamp light went on again
sounds like the power board caos need replacing. You can get the V26 chassis DLP power board repair kit at www.tvrepairworld.com which has the parts and the CD with instructions
Oct 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Constant flashing green light
I had the same problem. When I checked the lamp (that was only 6 months old) it looked good. I had a tech come out and he put in a new lamp and solved the problem.
Good Luck!
Apr 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
