Question about Dometic Rooftop RV Air Conditioner
R we still talking about the duo therm briskair roof &celing conditioner with no place to put the freeon mamawwyatt122142@aol.com
  • 36 Answers
There are usaully no places to refill Rv Ac units. You have to have very particular parts to fill most units..Tell me your exact Issue..
Posted on Aug 05, 2010
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Duo-Therm BRISKAIR on rooftop of houseboat runs, not putting out cold air. Also, fan doesn't seem to be running at top speed
Sometimes a weak capacitor will make a motor run slower so I would check that first. Also make sure the compressor is running. Let me know what you find. You may need to get the refrigerant charge checked too. By the way it may use the same capacitor for the fan and compressor.
May 26, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Duo therm briskair conditioner
check your power supply, 5 minutes is about the time it takes to blow a breaker
Aug 11, 2009 | Heating & Cooling
Dometec Briskair Duo-Therm Compressor won't quit running
Have you taken return air filter grille down at ceiling assy, & cleaned filter with dish soap & warm water? Check & see if you see little probe sticking out in behind there, and wipe it carefully as well, and make sure it's lined up to sense air flowing through there. Take a flashlight & look up into coils at front for lots of dust on them as well. Perhaps a thorough cleaning of all coils is in order if you say there's lots of dust, as choking airflow off with dust & dirt, will only shorten life of unit & use more hydro than necessary.
Jul 07, 2009 | Heating & Cooling
Ac blowing breaker
The unit will draw more current when hot. Check rating of the breaker against the rating recommended by the manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Aug 05, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
141 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
