Question about Vasco Digipass Go 3 (70403201249)
Hi i have a problem with my vasco device, when i press the "play" button appear on display this message "00000000". i need your help.thanks
What is the traffic button for in a 2002 alero
According to the owners manual
TRAF (Traffic): Press this button to receive traffic announcements. The traffic announcement brackets will appear on the display. TRAF will appear on the display if the current station broadcasts traffic announcements. If the current station does not broadcast traffic announcements, the radio will seek to a station that does. When the radio finds a station that broadcasts traffic announcements, it will stop. If no station is found, NO TRAFFIC will appear on the display. When a traffic announcement comes on the current radio station or a related network station, you will hear it, even if the volume is muted or a compact disc is playing. If the compact disc player was being used, the compact disc will stay in the player and resume play at the point where it stopped. INFO (Information): If the current station has a message, INFO will appear on the display. Press this button to see the message. If the whole message does not appear on the display, parts of the message will appear every three seconds until the message is completed. To see the parts of the message faster than every three seconds, press this button again. A new group of words will appear on the display. Once the complete message has been displayed, INFO will disappear from the display until another new message is received. Hope this helps.
Feb 25, 2014 | 2002 Oldsmobile Alero
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
My device NWZ-B133F once is powered on, it displays boot error
This issue may occur if the portable player was formatted via Windows Explorer. Follow these steps to correct this issue:
NOTE: If the message you receive is Format OK? , select Cancel .
1. Connect the player to the computer.
2. Click Start and then click My Computer .
NOTE: If the Portable Device box appears, click Cancel .
3. In the My Computer window, under Other , double click the icon for your portable player.
4. In the My Computer [Name of your device] window, right click the Internal Storage icon and then click Format from the menu.
5. In the Format box, click OK .
6. In the Format Complete box, click OK .
7. Close the My Computer windows.
8. Disconnect the portable player from the computer.
9. If it is not on, press the power button to turn it on.
10. Press the selector button repeatedly until Settings is highlighted.
11. Press the Play / Pause button.
12. Press the selector button repeatedly until Format is highlighted.
13. Press the Play / Pause button.
14. Press the selector button one time to highlight OK .
15. Press the Play / Pause button.
16. Once the player has finished setting up, Music Library will appear in the display and you can now use your portable player.
17. Test the player for proper functionality. If the error still occurs, reset the player by pressing the RESET button with a small pin or similar object.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Thanks for using FixYa.
Apr 07, 2011 | Sony NWZB133F MP3 Player
My sony mp3(nwz-b133f) got boot error how to slve it
Apr 06, 2011 | Sony NWZB133F MP3 Player
CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
Help
Don't return it! Your Action Replay DS is corrupted. To fix it, turn the DS on (with AR in it) while holding A and B. Then, at the white screen, after "Nintendo DS" but before "This product is not licensed or endorsed by Nintendo", hold down Start and Select while still holding A and B. A few seconds will pass and then the title screen will appear. A few seconds after it appears, release all the buttons. The screen will go white, so just restart the device. Now do a Quick Update in Action Replay Code Manager (on the PC) by pressing the Quick Update button in the corner of the window while the AR (still inserted in the DS) is connected via USB. After it's done, viola! A fixed Action Replay.
Apr 15, 2009 | Nintendo DS Console
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Lock message
Hi!
My DMR-ES10 appears since last month, the same message, and lets myself crazy!
Today, after a desperate try, pressing the buttons, I found the solution:
Simple press the POWER BUTTON and STOP BUTTON of the unit for a few seconds...
VOILá: The UNLOCK message appears in the display and the unit return to operate without the lock message !!!
For Lock again, press the same buttons at same way until appears the Lock message in the display.
This is an undocumented command...
I hope to help you!
Mar 25, 2008 | Panasonic DMR-ES10 DVD Recorder
Cordless phone
to play your messages
press the button with the speaker symbol on the handset it shows ans record on the screen, then press number 2 and your messages will play.
press * to delete the currently playing message DELETED will be displayed
to delete all your messages
press the speaker button ans record shows in the window, press the star button the display shows DELETE press ok to confirm the display shows deleted and you will hear a confirmation tone.
press c if you decide to cancel deletion
press and hold c to exit and return to standby
hope this helps you all,
Nov 29, 2007 | Lands Phones
Vasco Digipass Go 3 (70403201249) Logo
209 people viewed this question
Top Vasco Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Vasco Computer and Internet Expert? Answer questions, earn points and help others
