Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Massey ferguson 35 hydraulic lift will not pickup any weight, o rings on tube from pump to top housing newly replaced, not appear to be leaking, does adjustment of position of rocker arm increase or decrease flow of fluid to cylinder
  • 3 Answers
SOURCE: looking for repair manual for massey ferguson
Call JEN-SALES at 800-443-0625 or 507-826-3666 or www.jensales.com
Posted on May 28, 2009
  • 714 Answers
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
probably 90w gear oil
Posted on Jul 18, 2009
  • 165 Answers
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Posted on Feb 27, 2010
captjack163
  • 13 Answers
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Posted on May 01, 2010
roniecon
  • 6927 Answers
SOURCE: I have a TO-35 Massey
The only thing left to check is the timing,and the fuel,make sure there is no contamination in the fuel ,and no water,try a cleaner,and a dryer for the fuel.It does sound more like the fuel.
Posted on Aug 17, 2010
I asked the other day about a Massey-Ferguson TO-35 power steering problem. At a dead stop, the front wheels wobble back and forth violently.
replace the power steering control as there is a bypass occurring to the power steering ram or hydraulics in the box
talk with a power steering specialist or a massey service agent
Feb 03, 2017 | Cars & Trucks
Just rebuilt the hydraulic pump it will lift the arms,but when bush hog attached it will not lift
Could have cut a seal when building it. Could be a bad case. Could be the pressure block/ control valves are bad. Since yours works with little pressure. I would go after the control valves/block
May 20, 2016 | Cars & Trucks
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
Hydraulic failure
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Feb 15, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
M-f 35 exhibits jerky motion on hydraulic lift and front loader
Check the rear end oil level. Failing that try cleaning the hydraulic oil fillter.
Oct 23, 2013 | Massey Ferguson Aux Hydraulic Pump
Looking for wiring diagram for a Massey Ferguson 35 with 3 cylinder perkins diseal
You might look through these images:
https://www.google.com/search?q=1961+Massey+Ferguson+35+wiring+diagram&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Feb 18, 2018 | Toys
I have a 1950 ferguson to20 lift arm will not lift any weight ? this problem just happened is this a simple fix? like o-rings, check balls??? Thanks
maybe, If the hydro fluid level is up then you most likely need to change or clean the hydro filter. when they stop up they will cause it to cavitate. cavitation will add air bubbles to the fluid and make it look a little milky. It would be best if you can drain it and add new. please let us know if this helps. note that they will usually be jerky on lifting just befor no lift.
Aug 31, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Diesel getting in to sump on massey 3080 year 89
well its most likley to be the piston rings worn out there is a slght chance its a blown head gasket or duff injectors but im going to put my money on rings
long old job fixing this,, but at least you can get a set of piston and liners for it,,,
Oct 25, 2009 | Spec Cast 1: 16 Massey Ferguson 98 Tractor...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
1,010 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
