Question about Panasonic Televison & Video
I've got 2 Panasonic DMR-EX79 DVD Recorders, one is faulty (stuck in self check did not complete loop) my question is, is it possible to put the hdd from the faulty machine into the healthy machine to retrieve the contents of the hdd? Would there be any problem then putting the original hdd back into it's original healthy machine. Any help or advice is much appreciated, thanks.
    Top Expert:
  • Panasonic Master
  • 12,962 Answers
Assuming the hard drive is not faulty I do not see why not provided that the configuration in machine 2 is identical to machine 1. Hopefully the electronics of machine 1 did not enter some sort of identifier in the hard drive that would render it useless in another machine. (Ex: Win 10 does this but Win 7 does not!). Good luck!
Posted on Aug 28, 2017
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
nandosnut
  • 112 Answers
SOURCE: Self check for over an hour
While the unit is switched off, Jim, press and hold the STOP and Channel Up buttons (BLACK SQUARE and CH/\) on the unit (NOT the remote) for 5-10 seconds and your disk should eject.
Posted on Apr 18, 2009
SOURCE: machine stuck on remote dvd 2 setting
Try holding 1 and enter at the same time for more than 3secs
Posted on Nov 16, 2009
  • 60 Answers
SOURCE: Switched on my panasonic DMR EX79 HDD/DVD recorder
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Posted on Apr 12, 2011
  • 55 Answers
SOURCE: Hi. I have a panasonic
hi you need to chage the dvd code back to dvd 1 it explains in the instructions how to solve they can be downloaded free from panasonic website
Posted on Jun 23, 2011
Some new dvds record right through, others from the packet come to 'NO RECORDING POSSIBLE' at some stage - is this to be expected?
I've occasionally found that some brand new DVD-Rs are rejected by Pana recorders, and have put this down to manufacturing faults on the discs. It's usually not worth taking them back when one disc of a pack of 100 is faulty.
All I can recommend is that you use a renowned brand, such as TDK, Maxell, etc to reduce fail rates.
May 27, 2013 | Panasonic Diga DMR-EH75V DVD...
L.S. How to reset Panasonic DMR-EH55 DVD Recorder / HDD Recorder to factory settings?
You can either go into menu (pressing 'FUNCTIONS' button on remote) and look for 'RESTORE DEFAULT SETTINGS' or similar heading, or you can (while unit is on) on the front of the unit (not the remote) press CH UP and CH DOWN buttons together for 5 seconds - the unit will switch to standby. Give either one a try. (refer to page 60 onwards in your user manual - these pages detail 'settings').
If you cannot find your manual, it is available for download (free) - http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-EH55S.O#ts
I hope this helps in some small way. Thanks for asking FixYa!
Feb 12, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Switched on my panasonic DMR EX79 HDD/DVD recorder and came up with a U80 code (did not start up properly). Followed the troubleshooting guide in manual by turning machine on and off but this does not fix...
Hope this helps.
Jul 01, 2010 | Panasonic DMR-ES20EG DVD Recorder
Recorder keeps 'self checking' then taking dvd back to begining, although only on recordable dvd's, not rented. Are recorders worth repairing or are you better just buying another?
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 02, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-EH75V DVD Recorder
What a story ! Clean your laser eye with Rubbing Alcohol and a Q-Tip. Down updates to your Recorder from Panasonics Website., and install in your Recorder. Order your replacement parts from Panasonic but I do doubt you will need them.
Jun 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Mar 29, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Mar 13, 2008 | Panasonic DMR-E95HS DVD Recorder
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
