Question about Canon ZR200 Mini DV Digital Camcorder
Recording stopped working
Till yesterday I was able to use ZR200 happily. Suddenly recording stopped working. May I would have played with settings. The camera mode either displays a blank screen or the Canon logo. The playback functions are working fine. I can play the casette or i can see the images in the card in play (card) mode. But when I switch to camera(casette) or carmera(card) mode, I can see only blank screen or Canon logo if I set it as default start screen. When I get it into this state, Even turning it to the "OFF" position does not work. The only way to get rid of the blank screen is to remove the battery. Can you please help.
When I put a cassette into my Canon ZR200 Mini DV Digital Camcorder camera, it tell me remove the cassette whit a red light flashing. yesterday I used the same cassette and it works. I try whit other cassette and it tell me the same.
help me
Posted on Feb 11, 2010
  • 979 Answers
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Posted on Jul 02, 2008
Suddenly stops recodring
I love my Sanyo mp3 recorder I've been using it in church for 4 or 5 years. It never quits it can hold an extra gig with a chip and i can plug it into my computer to upload it in seconds. I say replace the old recorder
Nov 17, 2013 | Alesis Masterlink ML-9600 w/ Audio...
Did anyone fnd a solution to this... 'My wharfedale DVDR24F has stoppped recording-My machine has worked great up till now but it suddenly stopped recording. The blue light is on saying that it is but then...
Recheck ur unit wiring for a lose or damages wiring connections between the DVD recoder player and the tv.This problems,u tries many recodering,have same result?Yes,than 100% u have wiring problems issues.
Apr 03, 2011 | Televison & Video
Recording playback has lines through it.
try with head cleaner tape 2 or 3 times mostly it works if not change video head assembly
May 24, 2010 | Canon ZR200 Mini DV Digital Camcorder
My canon zr200 was working fine yesterday and i recorded and everything went well, i went to record today and although the camera said it was recording, i cannot get it to play back. all i get is a blue...
The laser lens on the camera might need cleaning. Use a q-tip and 90% alcohol to clean it, then try it. If that doesn't help, try another disc. If that doesn't work, I'm afraid it might require servicing. Get a quote before you get it serviced, sometimes it's just better to buy another one. Good luck!
Mar 15, 2010 | Canon ZR200 Mini DV Digital Camcorder
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable.
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Sep 24, 2008 | Canon ZR200 Mini DV Digital Camcorder
Recording does not work
Could bethat your Hard Drive is full. Make sure it isn't and if it is then try erasing some programs. Also, check the User's Guide to reset the unit (usually done by pressing a combination of buttons for about 10 seconds)
Jun 15, 2008 | LG RH266 Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Canon ZR200 Mini DV Digital Camcorder Logo
390 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
