Question about Jenn-Air JES9750 Electric Kitchen Range
Lower element not heating on JES9750 - Jenn-Air JES9750 Electric Kitchen Range
  • aaatrailers Aug 06, 2010
    You can't beat a man at his own trait. It is good to have a place to go for appliance issues.
    Brigadier General:
  • 3,513 Answers
Hi
Usually, when an oven won't bake, it's because the bake element( bottom element) is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Please check whether your bottom element has probably "blown" out. See if there is a small spot that looks like it exploded. It is similar to an extension cord getting warm and melting in a spot. You need to replace it.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 05, 2010
    My wife will laugh when she hears she was right. I don't like to parts swap as a trouble shooting technique so I inquired here. Thanks for the input,,,, as I am glad it will be a simple fix. God bless you as well.
What else can I try, my Intertherm water heater is not heating water off the lower element?
I should like to hope I have your answer.
If yours is like most U.S. model, it is called a 220 volt unit.
That is not really 220 volts, it is really 2 separate 110 volt units.
What that means is, there are actually 2 separate 110 volt hot wires to the water heater, usually one hot wire is black, and the other hot wire is red.
One is for the upper heating unit, one is for the lower heating unit. Perhaps your lower unit has blown the circuit breaker for that line.
I mean the circuit breaker in the main fuse box/circuit breaker box.
Did you test the lower wiring to see if the hot wire is hot?
If it is hot, be sure to test the ground wire, and also the wiring between the bottom and the top of the heater inside it.
God bless your efforts.
Jan 04, 2018 | Water Water Heaters
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
Left rear stove top electric burner does not work. burner element good. no power from stove to plug in module that has front and rear burner. front burner works.
ok you have a fun one becuase the sockets could be bad you need to check for 220volts at the plug in for the serface burners if no power there then bad switch
Jun 02, 2010 | Jenn-Air JES9750 Electric Kitchen Range
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Oven won't heat up fully
The problem is the thermostat inside is bad.
May 05, 2009 | Jenn-Air JES9750 Electric Kitchen Range
Jenn-Air JES9750 Electric Kitchen Range Oven Heating Problem
One or both of your oven elements are likely failing. I would replace them both. It's not hard job.
Aug 19, 2017 | Jenn-Air JES9750 Electric Kitchen Range
Jenn-Air JES9750 Electric Kitchen Range Logo
61 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
