Question about Haier Televison & Video
I have a haier p42l v6-t1. when i turn on the tv the light saying that the tv is on turns on but the screen stays black. i believe the problem has to do with either the video processor or the back light. how should i go about tring to fix this?
  • Haier Master
  • 5,531 Answers
For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors on the boards. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
To diagnose a problem with the backlight inverter, if you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing.
If the video board is bad, the menus and any splash screen would probably be visible when you turn on the TV or press the menu button.
I hope this helps.
Posted on Aug 05, 2010
HL32D1
Check the back-light inverter board for proper functioning. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 05, 2013 | Haier HL32D1 32 in. TV
Upgrade kit pdf file
Heard lots of problem with similar case for this tv,you need to buy upgrade kit from the haier itself, there also available at Sears you will get instruction sheet will contain all information all you need is screw driver to replace the parts Control Board TV-5210-39, Y-SUS TV-5210-35, Z-SUSj TV-5210-37, New EPROM Chip 2006 version TV-2455-03, Upgrade Label TV-4050-08 and Haier Service Bulletin SB-TV-0003 containing the instructions to replace the boards yourself.
Good luck..
Sep 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier LCD picture goes dark, sound only
hi, since your TV is under warranty,It is better to ask for a replacement a new one ..the problem is factory defect.
Apr 02, 2012 | Haier HL15R LCD TV
When i turn on my television it acts like it will turn on then the screen stays black. but the power button shows that is on. can anyone tell me what is wrong?
COULD BE A POWER SUPPLY RELATED PROBLEM. FLAT PANEL LCD TVS HAVE POWER SUPPLY FAILURES MOST COMMONLY. COULD BE VENTED CAPACITORS ON THE POWER BOARD OR EVEN CRACKED SOLDER CONNECTIONS.
Dec 17, 2010 | Haier HL46XSL2 46" LCD TV
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
Haier P42LV6-T1 picture
when TV overheats white lines come across the screen
May 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier Plasma TV problem
My experience with a Haier Plasma 42EP24S is that they have weak software chip that goes bad and can cause a number of symptoms from picture with no sound, will not recognize video inputs, or my current problem tv turns on and off irratically.  This is the second time i have replace this chip, which is the socketed chip on the vga/component/dvi input circuit card.  Last time i had this problem i ended up fixing it myself because sears took over 3 weeks and still could not figure out the problem.  I am working on obtaining this chip, probally get about a dozen so if anyone thinks this may fix there problem as well i my have some for sale.  michael@malobicky.com of Malobicky Digital Systems.
Oct 07, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Televison & Video Logo
213 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
