Question about Kenmore HE3T Washer
My HE3T washer is collecting water while it is idle. After each wash, all the water drain out fine. However, leaving the washer idle for 2-3 days, the water is starting to collect in the washer. I have to do a Drain/Spin cycle to empty out the water. Do you know what is the cause for this and how to resolve it? Thanks
  • 34 Answers
I had this same problem with my Kenmore Elite H3t. The problem for me was some stuck dog hair, a pencil, and one of my daughter's mood rings. :) Here's what I did to fix it: First, unplug the washer for safety. Then remove the three 7 millimeter or t15 torque screws from the front lowest part of your washer - which will allow you to remove the lower front panel. It will be easier if you prop the front of your washer up on a couple pieces of wood or bricks first, so you can get to those screws more easily. Be prepared for a few cups to a half gallon of water to come rushing at you for this next part: unscrew the white capped plug you see in front of you. This is where you'll probably find a sock, pencil, who knows...(check this regularly for debris in the future too.) Then, check your hoses for any potential leaks. You can try to see if your problem goes away now. If it still persists, it's likely you had the same problem I had. You'll need to remove the black tornado-shaped hose from the back of the filter assembly you were just working on - which is also attached to the bottom of the outer drum of your washer. To do this, take a pair of regular pliers - and reach around the back of the top of the boot to find the clamp tension release. Use your pliers to hold the clamp open with one hand, while gently pulling the clamp off the hose/boot. Do the same with the smaller/closer end of the hose. Wash the boot out in your sink (be sure you don't empty the contents of the boot into the side with your garbage disposal, or you might have to research another appliance repair section of this website. I found a small nail in my boot...was a miracle it didnt puncture the boot. Then, before replacing the boot - feel inside the hole at the bottom of your drum for any accumulated animal hair, socks, underwires...then you can replace the boot. Be sure to get it on all the way, which can be a chore if you lack good finger dexterity like me. I found that putting it back on required less detail work with the pliers - and was more easily able to do this job by hand. I was also able to put the clamp on the front side - in case I ever need to do this job again in the future. One last thing before plugging the machine in and giving it a test run: remove the drawer detergent dispenser. Then feel around in the front of the empty drawer tray for any missing detergent caps or chunks of anything. This can also cause issues - and can be an easy fix. Now, before putting the front of your washer cabinet back on, test it to see if you fixed your problem. Be sure you don't have any animals, children or spouses nearby before testing an open washer though. Electric shock isnt anything to mess around with. Good luck!
Posted on Dec 09, 2010
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
HE3t leaves water in drum after the wash cycle is complete. Already checked the drain clean out...still leaves water in the drum.
Since we are working on the drain side of things only 2 things can happen to not get the water out of your tub-1 the pump isn't working,something stuck in it- 2 you have blockage which we know is not in the trap-check conection to the tub and the pump and all discharge hoses-cheers Denny
Oct 15, 2013 | Kenmore HE3T Washer
Kenmore he3t front load washer doesn't turn on, only two beeps. I've tried unplugging it and same result.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore washing machine model 110 he3t code fo2
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
Everything works fine but it will not spin
Hi, you got water pump problem, some pump have a filter you can remove and clean, or some some small clothing could get into it. or you can open water pump and manually check for foreign object. you can empty machine, by lowering drain hose to floor level, you will need somthing to collect water, then check pump.
Aug 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
He3t washing machine bleach dispenser if full of water after a load of wash.
Pull disp out. Check to see if its clean. Put into sink and run a sead stream of water into bleach cup till overflows and syhpon tube begins to drain water. Turn of spicket while holding disp steady and level. If the water drains cold water valve is faulty or screen is restriced reducing water preasure. Poor water preasure will prevent proper syhponing. If disp doesn't syphon or drain water out while in sink its either faulty or dirty.
Jul 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Stinky, moldy smell on clothes
I agree with your concerns, but, unfortunatly, leaving the door open and emptying the drain trap is all you can do. I would also start washing your laundry with at least a 1/2 cup of borox with each load. This will help with the smelly cloths as well as running the monthly clean cycle or an empty express wash with only bleach.
Jun 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Nasty moldy smell inthe MAH2400A
a cycle with just hot water and chlorine bleach will help but you may have to work at it a litle longer to get the door seal any cleaner in future run a short cycle with bleach and leave door open between use as much as possible..there is a new tablet shaped cleaner out now that may help in routine cleaning ckd with local dealer or repair personel also may ckd grocery shelf
Jun 09, 2008 | Maytag MAH2400A Front Load Washer
Kenmore HE3T Washer Logo
111 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
