Question about Craftsman 25cc Gas Line Trimmer
Try to replace 2 gas lines that from the craftsman gas line trimmer, but forgot how to put them back...any manual availabel?
Can you show me a diagram?
Posted on Aug 12, 2010
Fuel lines rotted. Replaced but cannot prime. Primer pushes back into tank causing fuel to leak at cap vent. Would like to obtain parts manual
i recently worked on a chainsaw that i was putting back together and got the primer bulb lines crossed, it was backwards to the way it should have been, i recommend that you reverse the lines, it is an easy mistake to make when it can be counter intuitive like it was in my case
Jun 28, 2011 | Craftsman 25cc Gas Line Trimmer
I have a 25cc gas trimmer. It leaks a little gas from the clear, flexible gas supply line(s). Is it possible (practical ?) to repair a leak in the gas line(s) ? Can the lines be replaced...
They get replaced all the time. The "new" gas with ethanol tends to deteriorate them more quickly nowadays. Small engine repair shop has the fuel lines you need. Repairing them is not done.
If you have the Craftsman trimmer, just ask for about a foot or two of each of the 2 different size lines. They are called "Tygon" fuel lines. Runs about a dollar/foot for the stuff.
Nov 12, 2010 | Craftsman Garden
How to replace a craftsman weedeater gasline?
you hook one line to it the return line inside the tank
The line you used as a return line pull it back thru the gas cap hole and put that piece on one end of that line and pull it back in the tank until it stops and then hook the return line back where it belongs
May 14, 2010 | Craftsman Garden
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Gas lines on Poulan Pro model 112
i need a diagram or manual for a sears craftsman weed eater so i can put new
gas lines on it
Sep 06, 2008 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
283 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
