I switch my sansui sv2136i tv on nd da standby light just go on and off once.
3 Suggested Answers
SOURCE: TV switched itself off. Standby light flashing on
PANASONIC TV SHUT OFF ON ITS OWN WON'T TURN BACK ON
Posted on Jan 17, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Sansui SV2960
This is a common fault as the set on ageing deteriorates in the connections. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Jul 25, 2011
Testimonial: "Excellent advice. Thanks "
Sansui tv STL-32ME83DT flash the back light once then reverts to standby,so what could the problem
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 07, 2015 | Sansui Televison & Video
Sansui sty1232 it block in standby mode
Try unplugging your TV from the electric socket for a few hours or preferably overnight. Hopefully your TV will then turn on
Oct 04, 2014 | Sansui Televison & Video
Sansui sv2136i picture is getting smaller what can be the problem and how can I fix it
Your hi voltage circuits are dieing. There are many parts associated with the voltage needed for a full picture. It may or may not be worth the price of repairs on an older TV depending on how old the TV is.
Jun 03, 2014 | Televison & Video
I have 42" ,Sansui plasma tv .model number Sty 0342 . when i switch it on , the power led chages from red to blue, then suddenly goes red again .i've changed the power board but it keeps doing the same...
I have sansui television 42"model number STY0342, plasma 3D.when l turn it on sometimes it takes time to switch on after turning it on.it will change the standby light to blue.what might be the problem.
Dec 26, 2013 | Televison & Video
Tv wont come out standby
That is irritating to have a tv that is neither off nor on. I presume that you have restarted it. If not do, disconnect the tv and the router and other appliances that may be connected to the tv. Disconnect for two to three minutes, connect to electricity again and make sure that all cables are where they should be. Hope you get this sortedvout, kolbrun
Sep 18, 2013 | Sansui Televison & Video
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
Sansui tv model sv2136i is completely dead
Check it powerregulator section for any shorted component/s. Check fuse.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help
May 19, 2012 | Televison & Video
My DA-T500 is stuck on Tape and wont change to turntable or radio
You might have a gummed up switch. Try some contact cleaner and go from there.
Apr 29, 2012 | Computers & Internet
Standby light red
my precission tv model ptv1444 ic lock i dont have the original controll, quetion how cai i unlock the tv, thanks
Nov 27, 2007 | RCA F19426 19" TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
