I am having trouble setting up the load tray for printing on my MX310. I cannot widden the paper tray to more than 6" nor does the tray come up more than 6" The manual is not clear or I am dense. I am woking off page 15.
  • 552 Answers
Go to this link for support and downloads.
There is a manual that will download right to your computer and it shows graphics for paper loading etc.
Hope this helps if not let me know please.
Posted on Apr 26, 2008
    Brigadier General:
  • 3,614 Answers
Theres a slider guide on the center of the tray... did you find it
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
Using Lex. 4'x6" paper, my 901 is not
To properly lay the 4 X 6 in paper in the tray, please follow the steps below:
  • Pull tray completely out of the printer.
  • Move the paper guides to the sides of tray.
  • Use the photo paper outline on the bottom of the tray to help you position your paper.
  • Load your paper.
  • Adjust the paper guides to rest gently against the left, right, and bottom edges of the photo paper.
  • Insert the tray.
Make sure the correct print setting is configured before printing your file. With your file open, click File > Print > Properties > From the Paper Size list of the Print Setup tab, select 4 X 6 in. Click OK to save the setting. Click OK again to print your file.
Jul 24, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
We have a 4250. When printing from our software we get a message that reads "manually feed tray 1" or "click the check mark to print from tray 2". No matter what settings i change i...
This is often caused by software asking for paper that is not loaded in the printer. You can use the paper path test function in the diagnostics menu to ensure that tray 2 is working properly. Also check your driver settings to make sure that the paper size shown in the driver matches what is actually loaded. You need to also check and make sure that the paper type for tray 2 is set for plain paper, otherwise the printer will only print to that tray if you ask for the paper type that is set.
Jul 12, 2011 | HP LaserJet 4250n Printer
Hi, My Canon MX310 all-in-one is only a couple of years old and lately broke down. The problem is it doesn't take the paper correctly. Shrink it at the start of printing and shows that there is not...
My PIXMA 6000 has a paper tray on the bottom or else you can load the paper from above.
When the paper tray contains paper and is loaded it moves a switch that alerts the printer that there is paper available to the printer.
When loading paper from the feeder on the top of the printer there is a bar that kicks out from behind the paper that pushes the paper in to a roller on the other side. The roller grabs the paper and feeds it in to the printer. As the paper enters the printer a sensor detects it's presence.
Jun 12, 2011 | Canon PIXMA MX310 All-In-One Printer
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi Where do I load the paper in my Canon MX310?
The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals .
I hope this helps.
Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
I have Canon pixma MX310 and I just trying to set it up.I'm trying to print and there is message open paper out tray.What is that mean and how I can fix it
The printer will not print as long as the paper output tray is closed.
  1. Open the Paper Output Tray (2).
    Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
  2. Open the Output Tray Extension (3).
    Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
  3. Adjust the position of the Paper Thickness Lever (4).
    Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper.
Oct 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
24 people viewed this question
jasbo
jasbo
