FixYa.com
Tags:
D-Link DI 514 Wireless Router
Will it work
posted by steveng1983 on Apr 26, 2008
i have just bought a D-Link DI 514 Wireless Router for the intension of using my pc and x box 360 together from a ntl modem will this product allow me to do this i diont want a wireless connection though?
thanks for your help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 01, 2008
Not Rated (0)
serra_baby
Rank:Wiz Wiz
Rating: 84%, 48 votes
hello!
yes, the router will work with your pc and xbox 360.
You have to set the internet connection first between you modem, router and pc before you configure the xbox 360. try this and see if it will work with your network
you may try this and see if this help solve your problem
to set up your modem and router:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
to set up your xbox 360:
Step 1: Power down the Xbox and connect a regular straight thru Ethernet cable from one of the numbered ports on the router and plug the other end of the cable into the Xbox™’s Ethernet port.
Step 2: Power on the Xbox without a CD in the tray and the Xbox Dashboard should appear.
Step 3: Select Settings and press A on the controller.
Step 4: When the Xbox screen appears, select Network Settings and press A on the controller.
Step 5: When the Network Settings screen appears, select IP Addresses and press A.
Step 6: Under Configuration, select Automatic and press A on the controller. Take note that the IP Address being shown will be the Xbox’s IP Address. Press B to return to the previous screen.
Step 7: When the Network Settings screen appears, select DNS Servers and press A.
Step 8: Under Configuration, select Automatic and press A on the controller to save the changes. Press B to return to the previous screen.
Step 9: When the Network Settings screen appears, select PPPoE Settings and press A.
Step 10: Under Configuration, select Off and press A on the controller to save the changes. Press B to return to the previous screen.
Step 11: Once the Network Settings appears, select Connect and press A to test the connection.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Routers problems?
D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514
Hello, Currently there are 2... Answer This...
DI-514Dlink connectivity
Blocked windows!
hello! well my quiestion is... Answer This...
Ip Phone
My IP phone is connected via my... Answer This...
d-link di-514 will not allow...
my d-link 514 will not allow my... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
