Question about Garland Convection Oven - MCO-NAT Gas
Does this oven come with a gas regulator build in, in what do I need to get to hook it up.
    Sergeant:
    Champion:
  • 277 Answers
Call you local gas company. They will gladly assist you
Posted on Aug 05, 2010
My Zanussi ZKG5540 top oven often goes out after being properly turned on but only if we are using the main oven at the same time. British gas advise we gave great pressure and we have a new main all the...
sounds like the appliance regulator is not allowing enough flow to properly run both units at the same time.Make sure the top of the regulatr (the rectangular unit) the gas is hooked to at the unit from te main gas connection, is set for the proper gas . there usually a cap on the top of the reg. under the cap there is a adjstment scew or an insert that can be flipped to increase or decrease the flow of gas to the unit.
Mar 23, 2010 | Zanussi Ovens
No gas to the oven, range works fine
This video shows where the lever is
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 06, 2010 | Ovens
Stove top works. no gas to oven
you may have a bad ignitor if unit doesnt have a standing pilot.....there may be a lever that needs flipped on the regulator. the regulator valve is where the gas line hooks to on the stove
Used oven purchased in US to work in Trinidad and Tobago (Caribbean) Only LPG Gas is supplied here, it seems as if the gas type is not what the oven was designed for. Main burners fires up and then cuts...
Hi i was reading your problem go to the appliances parts store tell them you need a gas valve Regulator that will change it from lpg to natural gas its natural gas it needs on the the 10 psi i think it should go back on the 25 psi thats only Regulates the flow of gas to high an to low dats all..i can be reach babeboz2000@yahoo.com
Nov 14, 2009 | Blodgett DFG-100 Gas Single Oven
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Gas Line reconnected and now oven does not start up, pilot on
Check the hot surface ignitor if its not working valve will not open, It is located at the back bottom of oven. Sometimes they will appear to be work but if there isnt enough back emf the valve will not open.
Mar 15, 2009 | Magic Chef 9122 Gas Single Oven
Melting fenwall starter sytem
You need a gas engineer to verify that the regulator on the back of the unit is correctly adjusted. The incoming gas might be regulated to one pressure, but the oven works on a special pressure, controlled by the machine regulator. Also there is a small cooling fan in the control panel that keeps it all cool. The wiring can become detached or the fan fail if the control panel has been withdrawn harshly
Jan 07, 2009 | Imperial ICV-1-H Turbo-Flow Electric...
Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Jan 16, 2008 | Vulcan Convection Oven - VC44EC-208-1
Garland Convection Oven - MCO-NAT Gas Logo
83 people viewed this question
Top Garland Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Garland Oven Expert? Answer questions, earn points and help others
