Question about Samsung HCN653W 65" Rear Projection Television
On my hcn653w when i cut my tv on it produce a shadow of everything. what is the problem?
  • 22 Answers
Convergence amps are bad....Replace them or the whole board. W/ any experiance it's fairly easy. If not it will run about $400-$500@ the shop.
Posted on Sep 11, 2010
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
Hcn653w is showing ablurry picture. it will clear up for a minute and then gets back blurry.
Ur tv have a convergence problems,it dead.U know how to solders?U have a soldering iron,solders,solder Wicks?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Mar 30, 2010 | Samsung HCN653W 65" Rear Projection...
Concaved shadow
this is because of the magnetic interference, you better isolate the TV from the devices producing heavy magnetic interferences like Speakers Microwave, Cellphones and Cordless phones. Then go the main menu in that you will find setup option , in the setup option go to the picture setup you will find option called degauss just click on that, the screen will flash for a second and everything will be alright. Frequent degaussing is not advisable as it reduce the life of the projection tube.
Jul 25, 2009 | Toshiba 50H82 50" Rear Projection...
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Convergeance Board for HCN653W.
This is a very old post Do you do need Help?
Nov 13, 2008 | Samsung HCN653W 65" Rear Projection...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Blue shadow and lines
This would apear to be a convergence issue ..sometimes you can go into settings and converge it manualy.. if this is to far out of range. a service tech will have to adjust inservice mode. if the convergence cuircits are not failing. if so then there are cuircits that will have to be replaced. is this just a blue shadow?.. is there green or red shadows. if not it may not be a major repair.
Dec 18, 2007 | Samsung HCN653W 65" Rear Projection...
Red lines when watching DVD
Regardless of what inputs you use when the lines appear, that symptom suggests that the Proscan Module Samsung p/n#BP95-00140T is probably defective. That board is a plug and play replacement but there are no short-cuts to testing it to be certain that's the problem or the entire problem. That said, the top of the metal shield lifts off and the board can be pulled with no greater skill than a first year technician. The board is $184.25 plus shipping from Vance Baldwin - so if you're feeling lucky you could try this one yourself... Just be careful. If you have ANY questions drop me a note at premtech@willapabay.org and include the model number. Hope this helps Bill Good luck
Jun 05, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
