Question about Haier DM30EAL Dehumidifier
A PUDDLE OF WATER FORMS UNDER MY DEHUMIDIFIER WHEN IT IS RUNNING.
  • 40 Answers
Dehumidifiers have a container that holds the water the the unit extracts from the air. If that container is full or not placed correctly, the water will leak out of the unit.
Posted on Aug 05, 2010
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
HI, OUR DEHUMIDIFIER SWEATS ON THE TOP (FORMS WATER BEADS) AND PARTIALLY FORMS ICE.
>check if the steam creating by the dehumidifier is enough or balance to neutralize the fresh air supply of the dehumidifier by not creating a too much moist or more tha 40% relative humidity so that water beads would not form from the top of the dehumidifier unit or from its supply of fresh air.
Jun 18, 2011 | LG LHD65EBL Dehumidifier
I hooked up a hose to drain now I am finding a puddle of water under the machine. Did I hook up the hose incorrectly?
Make sure the rubber hose o ring is in the hose connector and the hose is tightened all the way./
May 14, 2011 | LG LHD659EBL Dehumidifier
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
My dehumidifier leaks and not shut off. The bucket is full, but the unit still runs and I notice water puddling under the unit and my rug is wet around the dehumidifier.
I don't have a Haier but I have a dehumidifier which has a float and when the float get to a certain point,it activates a switch for auto shutdown.If yours has the same setup,the switch is probably bad.
Good luck! Greg If not,let me know.
Aug 16, 2010 | Haier HDN655E Dehumidifier
Running, but no water coming out. Is forming ice
Your machine has a sealed system leak and is low on freon. Read your owners manual and there should be a 5 year sealed system warranty. If so you will need your purchase receipt and call an authorized LG dealer for an exchange.
Oct 09, 2009 | LG LHD45EL Dehumidifier
Dehumidifier leaking onto floor.
You should clean off the condensor coils with a vaccum and soft brush. Also, check up inside the area where the condensate drips into the collection reservoir (or goes directly into a hose attachment discharge) to see if something is partially obstructing the water flow and is dripping onto the floor, etc.
You might find that you've got some buildup of dust, dirt, and some other gunk that is mis-directing the water (condesate) that the dehumidifier is drawing out of the air.
Lastly, check the unit to see if it's level, but frankly, I highly doubt that's the issue, based on the 5+ years of good working service for you.
So long as the unit is still running and keeping the humidity in check, (if the above steps don't resolve the issue), I'd continue using it until it finally quits running, but I'd put a plastic boot/shoe mat under it to catch the small puddles of water.
The dehumidifier should draw the small puddles, so it'd be less expensive to get a $4 boot mat than dropping another $240+ for a new unit, as your's seems to be working fine, aside from the occaissional puddle issue.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Dehumidifiers
Haier DM30EAL Dehumidifier Logo
972 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
