Question about Maytag Dryers
My Maytag Performa (PYE2300AYL) dryer quit running in middle of load. It has been working fine for 7 yrs. I checked all obvious reasons (power supply, breaker, etc.) and then replaced the high limit thermostat which is also involves a type of fuse. The dryer still won't "turn-on" so I'm wondering if I should attempt to replace other fuses or look for some other reason why it is "dead".
  • 171 Answers
The first thing to try wold be the thermal fuse.  you can check with an ohm meter and you will probably find it open up.  replacing is an easy one by please UNPLUG the machine first.
Posted on Aug 05, 2010
Maytag performa dryer just quit
Open panel on Dryer, check belt has not broke or slipped off
Mar 28, 2014 | Maytag Dryers
I have a Maytag Performa dryer about 5 yrs old. It wont start anymore but makes a humming noise instead.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a Maytag Performa dryer and it quit working yesterday. There is nothing coming from it. What should I look for?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 20, 2011 | Maytag Dryers
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dryer Won't Start
most common problem with the dryers is blown thermal fuses, something gets too hot and for safety reasons the thermal fuse blows. You can also check your incoming power supply make sure the breakers havent tripped. part num( LA-1053 )about $30 comes with directions to install. its located under main top towards the rear of unit moundted to the side of heater.BE SURE TO TURN OFF ALL POWER BEFORE CHECKING ITS LIVE!!!!!!!!!
Mar 06, 2008 | Maytag PYE2300AY Electric Dryer
We had 3 power outages a couple of days ago and my Maytag Performa Dryer won't run now.
Obviously when you had the power outage the voltage and frequency fluctuated. If you had the dryer running at the time, then it has tripped. Check the power supply at the plug point first, if its good then check the machine it has to have a trip switch on it or a internal fuse. check them if they are good.
Jan 10, 2008 | Dryers
Dryers Logo
155 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
